Results 1 to 1 of 1
October 8th, 2015 03:25 PM #1
Good day po mga sirs. i still have my 2004/05 dmax (first gen) 4x2. nasa 130,000km lang po mileage (brand new ko po siya na binili kaya ako po yung original owner. ayaw ipabenta ng misis ko siya na daw gagamit hehee. had it also re-freshed for the last weeks (new pads, resurfaced brake rotors, engine oil, filter, fuel filter, new enginer gaskets, new brake fluids, steering fluids, new cooling connectors, new evaporator for the aircon, etc (after several years na di ko pina check!) now since di niya papabenta, i might as well make her drive look better.
Can you guys refer me kung saan makakabili ng 2" quick lift (shackle and spacers) para po sa model na ito?
Or is the quick lift for the 2nd generation dmax same? plan to install a tire that is bigger but same wide lang po. thanks in advance for the help.
I'm based in cebu by the way so if meron po sa banaue, ipapa ship ko na lang po. thanks for the help.
