Results 271 to 280 of 309
- Jun 2015
- 2,751
May 1st, 2022 05:28 PM #271Battery pack ng Deerma VC25 after ko baklasin isa-isa ang anim na 18650 2200mAh na cells. Pahirapan ang pagbaklas. I'm now charging 2 cells at a time (yun lang kasi kasya sa charger ko) to determine which ones are failing. All cells have been drained to less than 0.5V.
Not even sure yet how I'll put back the batteries. Baka i-solder ko na lang kaysa spot weld.
Seems to me designed to be disposable itong Deerma otherwise they would have made the battery pack replaceable like some (perhaps all?) Dysons
Sent from my 3210 using Tsikot Forums mobile app
- Jan 2008
- 4,726
May 1st, 2022 05:46 PM #272
- Jun 2015
- 2,751
May 1st, 2022 06:03 PM #273Can the old tin still be used kung i-spot weld?
- Jan 2008
- 4,726
May 1st, 2022 06:17 PM #274Hindi na din.. sira na masyado eh.. may risk of shorting yan pag masugatan yung battery sa positive side..
Possible din na sira yung BMS ng battery dapat kasi nag balance charging yan.. buy ka nung imax b6 charger.. para pag na out of balance yung charge, pwede mo charge yung cell na out of spec without destroying the whole pack
- Jun 2015
- 2,751
May 1st, 2022 07:38 PM #275My Xtar VC2 doesn't seem to be having trouble charging the overly discharged batteries. I could probably still keep these for portable fans. Maghapon nga lang nakaka 1 pair pa lang ako.
No issue kaya if i replace the INR 2200mAh batteries with NCR 3500mAh? Or will it depend on the board kung mapapakinabangan ang additional capacity?
- Jan 2008
- 4,726
May 1st, 2022 11:36 PM #276Yup you can use naman higher capacity 18650..
Pero hindi talaga advisable mag recharge ng lithium batt pag over discharged...some chargers nga hindi gagana eh as protection... pwede kasi maging unstable yan at sumabog
- Jun 2015
- 2,751
May 15th, 2022 08:55 PM #277
May 15th, 2022 09:45 PM #278
- Jun 2015
- 2,751
May 16th, 2022 01:31 AM #279I get a lot of satisfaction in DIYing stuff so I'm fine with all that effort and expense.
Ang laki na ng binaba ng presyo ng Deerma and I can guess why ganyan ang price drop. Kung same unit lang rin ang ipapalit ko wag na, hehe. I probably got a lemon pero medyo shoddy talaga ang workmanship kaya never na ako bibili ng brand na ito.
Sent from my Nokia 6.1 using Tsikot Forums mobile app
May 16th, 2022 03:27 PM #280
Gaano lang ba tumagal ang sa inyo? Itong amin kasi kakabili lang at madalang pa gamitin kaya do ko rin alam baka di rin tumagal battery nito. They could have at least made it na easily replaceable ang battery. But then again, baka ang purpose ng design is to make it hard to, ergo, disposable.
