Results 71 to 80 of 138
April 3rd, 2020 08:33 PM #71
Are you land-based or at sea? I can relate as I'm stuck here on my work and I can't go home. It has been a month already! I used to work abroad but for a weak hearted guy like me, I truly can't stay for that kind of work even if the pay is good.
Going back, it was a good timing for me that I covered the car before I left it. I never thought I'll be stuck here for over a month.
Hopefully, no rats and cats will make the engine bay its home and playground.
April 3rd, 2020 10:32 PM #72
May 25th, 2020 09:26 PM #73
Just saw this on fb.... has anyone tried using this? Its a foam cleaner and virtually cleans everything inside your car.
- Jan 2008
- 4,726
May 25th, 2020 11:03 PM #74Depends on the surface you want to clean. Try pro choice products.. been using them to clean my cars.. for interior plastics try pro choice all purpose cleaner. Dilutable so very economical.. very effective in removing "libag" hehe.. then apply sunshield to rejuvenate and protect the plastic.
For carpet or fabric, just use liquid detergent mixed with water.. brush the carpet with microfiber cloth then use a wet and dry vacuum to dry clean
May 26th, 2020 09:10 AM #75
June 2nd, 2020 09:29 AM #76
Can I use the quickleen and pro choice to clean the car ceiling? If yes please guide me on how to go about it as to not damage the car ceiling because its dirty especially near the rear aircon vents. Thank you
June 2nd, 2020 04:14 PM #77
- Jan 2008
- 4,726
June 2nd, 2020 10:31 PM #78NO..
Eto tried and tested ko na.. warm water with liquid detergent (breeze blue) mix it well..medyo tapangan mo yung detergent then use a soft microfiber towel and gently wipe the ceiling. Very gently!! Pat the wet towel into your ceiling. use hair dryer to warm the ceiling till dryLast edited by yapoy86; June 2nd, 2020 at 10:33 PM.
June 3rd, 2020 11:32 AM #79
I see. We are using ariel and surf powder. I tried the quickleen to clean the sidings and headboard and it gets the job done those hard to remove stains in the floor sidings are gone just need to use a toothbrush to scrub it a little bit. Thank u sir.... will try it at the back small portion im scared that i might not came out well.
- Jun 2005
- 3,770
June 3rd, 2020 01:43 PM #80Bumili ako nung rivers na degreaser sa lazada noon. Netong quarantine, nagspray ako ng ng kontinsa ceiling then wipe. Mabilis lang. Tanggal yung dumi agad eh.
Sent from my MI MAX 2 using Tapatalk
6-11k. depende sa brand.
2016/2017 Isuzu MU-X
