Results 21 to 30 of 33
June 5th, 2004 02:21 PM #21
Medyo makaluma pa kasi yung AT ng Hyundai, instead na tumaas ang rpm dapat engage nya agad ito sa lower gear. Kumbaga nangangapa yung AT nun.
Unless papalitan mo sya ng newer tranny setup which helps and costs as much.
August 26th, 2004 07:55 PM #22
to all the starex owners here who replied, how often do you change your front brake pads? our unit kasi is 2002 model from HARI and they keep on changing our front brake pads every 10k km. i examined the pads and hindi naman kami nila niloloko coz may mga nabakbak na layer dun sa surface ng pads so di talaga pwede sandpaper. the discs are fine and it really points to crappy korean brakepad workmanship. m really looking forward to replacing them with mitsubishi parts should it happen once agen
August 26th, 2004 08:11 PM #23
Our unit still uses the original pads since it was bought in 1998. I do check them from time to time, no sign of chip offs. Just the normal fade of pads.
Baka naman po warped yung rotors kaya matakaw sa pads? Korean metals are well known for its weak metal parts.
August 26th, 2004 08:44 PM #24
On Korean brake pads:
I wore down a front set in just one year of driving my old Kia Besta. I switched to a similar-looking off-brand (made in Japan) pad afterwards and my problems disappeared.
The Starex is a nice vehicle which traces its roots to the Mitsubishi Delica Star Wagons (hence the availability of 4x4 models).
We were really tempted on getting one. But only the MB100 could fill the space/budget requirements we have.
The Korean-market only Starex Limousine is what I want. hehehehe. Explorer Mark III on a budget.
August 26th, 2004 09:42 PM #25
sir ungas: yep, i have eliminated all possible factors and it seems na pads and discs na lang ang areas to consider. sa next check-up ko pa malalaman which of the two is the culprit. mabait naman kac yung staff sa HARI kaya i take their word. tsaka naisip ko, kung may problem nga yung discs, sasabihin nila na palitan na agad (money-making scheme). tnx 4 d reply sir =)
Otep: so brakepad ng space gear swak sa starex?
August 26th, 2004 09:47 PM #26
momoy,
It should fit. Unless Hyundai modified the original design. Other consumable parts like filters, etc. are interchangable.
August 27th, 2004 09:31 AM #28
pagbumili ako ng van starex ang pipiliin ko. sa price and performance patok siya. puede pang mag pa customize ng grab handle na wood. diba ungas?
- Jun 2004
- 135
August 27th, 2004 11:44 AM #29in fairness magandang van sya, leg room and airconditioning oks na oks sya, kaya lang makalampag pag di puno. ingatan nyo lana ang poer window, iwas lang kayo sa lubak. pa chek nyo lagi engine,
August 27th, 2004 02:21 PM #30Originally posted by afrasay
...puede pang mag pa customize ng grab handle na wood. diba ungas?
Nung nabili kasi yung amin walang grab handles, I just happen to tinker with its panels and took them out. Nakita ko na may naka-abang na butas. So, I just ordered our carpenter to make three handles for it.
Just a moment... just checked my vin. mine not affected. i read somewhere 2018-2019...
Suzuki JIMNY [merged threads]
