Results 1 to 7 of 7
February 16th, 2014 03:46 PM #1
Good day tsikoters!!!! Question for a friend,,,Super Grandia VS Grand Starex VGT kung sa akayatan daw po ba anong mas malakas,sample daw po kakargahan ng tig 10 sacks of rice both SG and GS ano daw po kaya ung mas makakaakyat ung hindi hirap.....he keep on saying kase ang Grand Starex matulin lang kase high speed ang differential tas ang Super Grandia Low Speed ung differential kaya mas malakas daw humatak kesa starex...... nahirapan na ko mag explain about engine horses and engine torque...........by the way he is a TOYOTA FAN BOY...
- May 2006
- 913
February 17th, 2014 12:11 AM #3
Once you're out of first gear, the rear differential gearing doesn't matter at all. The GS VGT will eat the Super Grandia for lunch on the road up to Baguio.
February 17th, 2014 11:44 AM #5
Well, Toyota's got a lot of low end torque. Or at least their transmission is designed to make the most of whatever torque it's got at low speeds. How much low speed climbing with 10 sacks of rice does your friend theoretically need to do anyway?
- May 2006
- 913
February 17th, 2014 03:12 PM #6
- 508
February 18th, 2014 07:07 PM #7I think with thinner air a turbo engine is more potent, but low end gearing is always key to any hauler. Try watching TFL cars on you tube. Those guys live in Colorado mountains so they always compare performance in higher attitude conditions. They also explain that on higher altitude there is always a loss of power due to air density across the range and mentioned that a forced induction system helps alleviate this.
If the toyota van has better gearing and a good FI system I would say it can beat the hyundai van, but if hyundai has a better engine more so a variable fan and proper gearing then I would say the Hyundai van will win. Usually naman Diesel engines with turbo would start boosting between 1500-2000 rpm. If lower band range therefore no boost and poor gearing useless ang turbo kasi di nag generate ng power to boost torque.Last edited by T|tan; February 18th, 2014 at 07:16 PM.
Thank you!
