Results 1 to 8 of 8
- Feb 2003
- 618
February 21st, 2004 10:32 AM #1bale naka locate ito sa taas ng secong row and third row seats,yung ilaw, may mood,door...etc....apat yata ang swith...nasira!...pag pindot nung isa, ayaw ng bumaba yung isa so nag doble ang ilaw...
guys what did you do..saan nakakabili ng replacement ng switchesand around how much...is it advisable to fix ?thanks
February 21st, 2004 04:12 PM #2
Mood switch will require you to press the same button again to turn the light off.
What you could do is try to press another button except for the mood light switch to pop the stuck ones. If that can't help it, Banawe boys can tinker with the switches and change them for you with local parts, if available. If all else fails, meron namang nabibiling bagong set.Last edited by Ungas; February 21st, 2004 at 06:01 PM.
- 10,620
February 21st, 2004 06:05 PM #4
ECT switch is for AT version, power & economy shift pattern. Nalimutan ko lang kung anong ibig sabihin nung ECT.
- Feb 2004
- 102
February 22nd, 2004 09:47 AM #5according to the manual, ECT is electronically controlled dual-range (Power/Normal) transaxle.
and yes it is for A/T versions.
February 22nd, 2004 11:46 AM #6
Sirain talaga yan. Punta ka sa mga used car dealers. Nagagawan nila ng remedyo yan using alambre and stuff.
Pero yung MOOD, pwede talagang sumabay sa main interior lamp.
- Feb 2003
- 618
February 23rd, 2004 03:46 PM #8
Try fixing it yourself first baka makuha pa.
Nagkaron nga pala ko ng same problem with my Besta cabin lamps. Yung mga map lamps stuck parati.
Konting butingting lang ok na ulit. Masyado lang atang mahigpit ang pagkakaturnilyo sa kisame.
Thank you!
