Results 131 to 140 of 151
- Feb 2009
- 15
February 28th, 2009 05:42 PM #131
- Jun 2007
- 93
February 28th, 2009 05:52 PM #132could you be more specific?
does your stereo, horn /lights work in ACC position?
When you turn it to ON position. does the usual lights light up?
When you crank the engine, does it crank or do you hear the tik tik sound?
If i remember correctly, you had the foglamps changed to 3000K HID
and your HU was also changed. right?
- Jul 2006
- 186
March 2nd, 2009 10:28 AM #133
happened to me too...they replaced the battery...however, after a few months..it happened again...they cant replace the battery na raw cuz the warranty on the battery lapsed already (warranty on battery is 1 yr i think..and this starts on the orig release of the vehicle...not on the date of the replacement)...
i just got a battery outside..ac delco...no more problems! i think there are factory defects talaga on the orig battery!
March 3rd, 2009 04:48 AM #134
- Feb 2009
- 15
March 4th, 2009 02:21 PM #135
- Feb 2009
- 15
March 4th, 2009 02:32 PM #136
Tol Chuaa, tnx sa info, i guess factory defect ang battery naibigay sa akin, kasi according sa casa they will check the battery first and everything will follow. so for now, am observing it muna, as much as possible i dont want to bring my car there, e wala pang plaka e, binyag na ng service , nakakahiya e.kaya observe lang muna.
- May 2008
- 6
April 22nd, 2009 11:32 PM #137Hi,
PLS HELP!
Have you guys experience this, when i reach 120kph in nlex my steering wheel starts to vibrate. Sabi ng WHEELS na ka align na man daw. So i was wondering what could be wrong. I dont experience this before even at 160kph.
Thanks in advance for the advice.
Tsikot Member Rank 4
- Jan 2007
- 2,326
April 23rd, 2009 12:40 AM #138
- Nov 2007
- 68
June 6th, 2009 10:07 PM #139have expirience this same problem,brought our unit to the casa and they found out that the fuel filter has some clogged in it,(due to the quality of diesel fuels being used),i could not believe it though coz i also thought it was from the wheel alignment,.,.,'til the casa explained that its because the engine is lacking from fuel supply due to the clogged in the fuel filter, and is sucking more air than fuel,kaya nagkakaron ng vibration sa high speeds like 120kph pataas.,.,and mapifeel natin ito sa manibela kasi medyo pigil na ang sf natin sa high speeds,.,.,.after our fuel filter has been changed ok na ulit siya wala na vibration and smooth driving na ulit mas mabilis na tumaas ang speed,even exceeding 160kph no vibration sa steering wheel at all.,.,.,
hope this helps,.,.,.I'm back after long time hehehe.,.,
June 7th, 2009 06:50 AM #140
Traffic!
