Results 21 to 30 of 32
couch potato
- May 2005
- 1,384
August 5th, 2005 05:51 PM #21OT: i need new glasses .. i was skimming the topics tapos ang naging basa ko dito eh .. "Pls Share: *** tips and common problems" ..
August 5th, 2005 05:56 PM #22Originally Posted by mrpink
- Jun 2005
- 325
August 5th, 2005 06:56 PM #23I still have my '99 Starex TCI A/T with only 48T km. in odo, so far very reliable, except for minor nuisances as mentioned in this thread-door handles, cabin lights, etc. Matibay suspension - I brought it through dirt road, up Mt. Makiling up to end of the road to summit past mud springs, even up Mt. Sto. Tomas in Baguio - so far no suspension squeaks. Very comfortable ride. Palitan mo lang yung orig Korean tires - mabilis umoblong at bumukol ang sidewall. I now use Yokohama Super Digger tires (same size)-mas softer ride and very quiet.
I use Shell Rimula-X every 5Tkm oil change. I just had it undergo Carbon Clean at Betan last month then started using biodiesel at 1% - wow, parang gas na ang acceleration nya ngayon. Very sensitive throttle response, sarap ihataw. Turbo performance is excellent.
- Sep 2005
- 33
September 28th, 2005 03:26 PM #24i have '98 starex, bought it in 2001. 85,000km na ngayon. When buying 2nd hand always replace all fluids specially transmission and engine (eto unahin dapat). Minor problems lang sakin lahat naman mura lang. May persistent leaking gasket sakin sa halfmoon, repaired sa casa bumalik, pero pinagawa ko sa banawe di na bumalik, mura pa php1k lang. Bigla rin namatay makina recently, pero cause lang pala loose electrical connection ng injector. Yan yung matabang wire na itim papunta sa injector. Aircon din palit ng usual consumables like dryer, evaporator etc.
I use Shell Rimula X 15w/40. Wag na kayo mag synthetic (or semi) kasi diesel is a dirty engine by nature and shud be oil changed every 5k km so sayang ang longlife ng synthetic. And diesel is high pressure engine (2x pressure than gas engine) so kelangan nya thicker viscosity oil to help leaks in seals and rings.
Overall, im very happy, very cheap to maintain but starex feels expensive.
Will sell it next year.......and upgrade to newer starex.
September 28th, 2005 05:17 PM #25Originally Posted by OTEP
- Sep 2004
- 62
October 1st, 2005 09:02 AM #27mas ok ba yung starex sa crd engine manual compare sa innova G crd manual? well my mom and sis was thinking to get a new car.
- Jun 2017
- 2
June 29th, 2017 04:23 PM #28Hi. Bago lang po dito. I have a 2001 svx manual transmission which worked well until last night, napansin ko on idle (with engine on) may ingay galing sa ilalim na parang may nagkikiskisang bakal pero kapag inapakan ko yung clutch ay tumatahimik siya. Sabi ng isa naming kapitbahay na baka release bearing daw. Any idea kung ano po ang problema dito, balak ko na rin dalhin sa pagawaan pero hindi ko alam kung saan dito sa amin sa project 8, qc may mahusay na talyer...
- Jan 2017
- 227
June 29th, 2017 04:35 PM #29
- Jun 2017
- 2
June 30th, 2017 10:22 AM #30^ sir mcoy thanks po... lumang thread napo ito kaya nagbakasakali lang ako kung may makapansin kaya maraming salamat po sa reply... nadadaanan ko napo iyang pitstop kaya itry ko po dalhin dun itong sasakyan ko. Presyong casa din po ba sila?
Daming issue ng SU7:grin:
Xiaomi E-Car
