Results 1 to 4 of 4
December 1st, 2012 06:48 PM #1
hi, would like to ask if anyone has encountered the same issue with the Gen1.5 Tucson CRDi?
1. Coolant level naubos (below MIN) buti naagapan at na-check ko agad so dagdag tubig
2. radiator fan not stopping while naka aircon hindi naman ako naka AC MAX and 3/4 yung temp ng aircon, usually alam ko OFF and ON ito dapat
Napansin ko ito while i had a 20k PMS and had my engine washed. May sensor kayang tinamaan?
Aircon minsan nagiging mainit but when turned the AC off then on, ok na.
- 52,727
December 2nd, 2012 12:11 AM #2when was the coolant level last checked?
did the problem start only after the wash? or was it already there even before, but you noticed it only when you had the wash?
btw, how long have you had this car? is it a recent acquisition?
you can probably have some basic checking like check the relays, but... cars are electronic now and not that easy to work on anymore..Last edited by dr. d; December 2nd, 2012 at 12:45 AM.
December 2nd, 2012 01:09 PM #3
December 10th, 2012 05:46 PM #4
found the problem na pala. the Radiator reserve had a leak pala. have to replace via warranty.
