Results 7,271 to 7,280 of 7661
- Jul 2013
- 27
December 6th, 2014 11:59 PM #7271Hi all. Need a little help lang. May nakaexperience na ba sa inyo an issue with central locking na parang nag lock/unlock sound siya when it shouldnt? when i lock all doors from driver control, then open ko yung door, dun yung sound (3x na parang naglalock/unlock) tapos hindi rin maoopen ang boot/cargo door kahit iunlock ko na with the key. nawawala lang naman on its own after a little while and no other problems with unlock/locking. it's been happening intermittently for a week now, though there are days that it doesnt happen. a little over a year pa lang tucson crdi ko. covered ba ito sa warranty?
thanks for any response. God bless.
December 9th, 2014 01:44 PM #7273
Remove negative terminal from battery. Leave alone for about 5 minutes. Then ikabit mo na. That is hard re-set, this procedure should clear any minor faults stored in your ecu. But major trouble codes would need to be cleared by the dealer. Of course pag may major trouble code, meron sira yan which the dealer would troubleshoot for you.
__________________________________________________ _______________________________
Was fiddling with the trip meter this morning, and found out my fuel mileage ....... 11.5 kms per litre.
Considering that our Vios gets 12 kms/litre on average, that is not bad .........
Not bad at all ...Last edited by lowslowbenz; December 9th, 2014 at 01:48 PM.
- Jul 2013
- 27
December 11th, 2014 08:53 PM #7274Good evening mga boss.. How do i go about claiming warranty from a hyundai dealer? nagsara kasi kung saan ko nabili yung unit namin (Hyundai GH), but they told me I can claim warranty at any Hyundai dealer.
- Jun 2008
- 1,741
January 7th, 2015 01:50 PM #7276
Was anybody here experienced unintentional acceleration of your unit either on braking or slowly moving to a parking area?
Happens number of times to me, actually doesn't matter if AC is on or off. What do you think is the culprit? Tried resetting the ecu by taking out neg battery terminal but still rpm rev up without touching the accelerator pedal parang humahatak pa rin kahit brake's applied already.
Tucson unit 09model auto trans and 48k odo reading.
Thanks in advance!
January 8th, 2015 12:57 PM #7277
Tucson boys, has anyone of you tried this?
Diesel Tuning Philippines > Diesel Chip Tuning and Performance Tuning Box Philippines
The Tucson is fast out of the box, but .........
- Aug 2009
- 63
January 10th, 2015 10:14 AM #7278Sir ano nga Part# ng Fuel Filter for 2010 Tucson Revgt CRDI?
Thanks
- Oct 2013
- 15
January 11th, 2015 12:50 PM #7279Question Mga Sirs,
Had my Theta GLS Tucson serviced (15k pms) last week and was told that brake pads need to be replaced and the rotor disc are due for a machine repair. Normal lang ba ito for 15k (over a year na yung unit)? Hindi daw covered ng warranty kasi wear and tear siya.
Hindi rin gumagana fog lights - most probably electrical/headlight switch daw problem - this one covered dapat daw ng warranty and the service advisor will just wait for approval from HARI daw.
Questions:
- Again, normal lang ba magpalit ng break pads at mag repair ng rotor discs at 15k?
- Kung pinaayos ko ba sa labas brake pads void na ba warranty?
Thank you, Sirs.
Regards,
Ace
- Oct 2013
- 15
January 11th, 2015 12:58 PM #7280Question Mga Sirs,
Questions:
Thank you, Sirs.
Regards,
Ace
