Results 1 to 10 of 10
November 25th, 2010 07:05 AM #1
guys, need advice on where i can have my Hyundai Matrix CRDi fix.
1. underchassis, there is a knocking sound when making a turn either left or right.
2. i think the turbo not working, low power on demand, low rpm.
- Jun 2008
- 1,741
November 25th, 2010 11:47 AM #2Just curious with your problem.
1. underchassis, there is a knocking sound when making a turn either left or right. Kahit sa any gas station service (ex. shell) kaya ma pin-point ang problema nito. Subukan mo dalhin for wheel alignment. Check nila ang condition ng steering system, syempre maririnig ang "knocking". Base on my experience they will not do alignment work as long as there's problem in the steering system (loose ball joint, etc), they will tell you to fix the defect.
2. i think the turbo not working, low power on demand, low rpm. This is not a sure turbo charger problem. When was the last time you change your fuel filter? This is the first item you have to check. How about the air filter, what is the condition? Is the air hose connection from t/c>inter-cooler>engine intake manifold is intact & no leakage? If the tail pipe blows black smoke: Please check/clean the egr valve. HTH
invite you to join this group. read rules & post your problem. http://teamhyundaiphils.proboards.com
December 8th, 2010 01:27 PM #3
thanks for the input.
regarding the underchassis problem, i found out that the CV joint is the culprit and need to replace.
grabe ang mahal sobra ng CV joint!!! 10,700 pesos... right side lang iyan.
kailangan ko replacement ng 1 set which means both left and right needed to be replace... baka may alam kayo na replacement parts para makamura sana... thanks
regarding sa crdi turbo problema pa din ayaw talaga mag kick in... mahina acceleration, malakas ang fuel consumption...
help...
- Jun 2008
- 1,741
December 8th, 2010 02:51 PM #4vgt turbo charger ba yang matrix? baka ang vacuum actuator or similar actuating device is not working. Pag vgt at hindi working ang actuator para sa adjustable nozzle vane sigurado hindi yan mag boost or mahina ang boost. opinion ko lang po.
Yung CV baka pwede repack (regreasing) pansamantala habang wala pang pamalit.
December 8th, 2010 03:13 PM #5
sir try mo sa goodgear sa pasay mura parts dun. alam ko dun din kumukuha ng parts yung casa.
BANNED BANNED BANNED
- Jul 2010
- 1,114
- Mar 2011
- 11
April 7th, 2011 01:22 AM #7
- Feb 2012
- 13
February 26th, 2012 05:29 PM #8
April 7th, 2012 09:33 PM #10
Hi Niky. I would like to know how the Chuaed's CV joint was resolved. How much was the approximate cost for the parts and labor? I am looking at purchasing a 2006 matrix crdi. Walang kausok usok pag start at pag rev, ganda ng ride pero when I made u-turn, lumalagatok yung cv joint. Before I decide to get it, would like to know kung ganyan talaga ka mahal ang parts ng matrix. Ang lakas talaga ng engine matrix, paakyat kami ng garvel hill at 2nd gear, walang kahirap hirap. Hope you can help me decide. I am choosing between the matrix and a 2000 Ford Ranger, both priced at 300K.
2024 Honda City V with Honda Sensing: 5 Things we like | Top Gear Philippines Top Gear Philippines
2020 Honda City
