Results 181 to 190 of 224
July 15th, 2019 10:21 AM #181
- 53,434
July 15th, 2019 10:25 AM #182cruise control is nice, if one has a nice, long, boring highway to drive it on.
July 15th, 2019 11:16 AM #183
- Jun 2019
- 24
July 15th, 2019 11:34 AM #184
Meron din naman benefit. You run about 5 to 10 mins on SLEX/TPLEX before you either click to speed up or step on the brakes. Then you set your cruise again. It does seem to add more complications to the driving but I felt more relaxed than the normal keep your foot on the gas pedal and constantly looking to make sure you are not going over the speed limit too much.
I guess the constant interaction also helps keep me awake hehehe
July 16th, 2019 06:51 PM #185
- May 2019
- 312
July 29th, 2019 04:43 PM #186That's bs man, modern cars have engine splash shields and a water tight sealing all-round. Water inside the engine would create a milkshake like mixture inside. I suspect that the car didn't have enough oil or he just got a lemon car. He should email or write a formal letter to Hyundai and insist that the car hasn't been exposed to severe "water splashing" other than a normal rain in the city.
- 53,434
July 30th, 2019 01:16 AM #187some cars' fronts are designed to maximize air flow into the engine bay, so as to maximize engine cooling.
unfortunately, i believe, it also encourages water to go in.
also, heavy water spray from heavy rain or, more likely, water thrown up by nearby cars' tires as they cut thru minimally-flooded road surfaces,
find their way under the bonnet in the engine bay, and into an ill-positioned engine air intake that's sucking everything within reach..
in a 1600 displacement engine, as little as 50 ml of water sucked into a cylinder, can hydrolock that cylinder.
nice thought exercise, this.
July 30th, 2019 01:24 AM #188
Reminded me of the AMG C63 that died because it hit a puddle of water. haha
In SHOCK.. The Mercedes is MORE than broken.. AGAIN (I WISH this was clickbait) - YouTube
July 30th, 2019 09:04 PM #189
Looks like the air intake is right on the front grille of the kona.
Hyundai Kona - Air Cleaner Repair procedures - Intake and Exhaust System
July 30th, 2019 09:15 PM #190
I've used Stainz Out and Stain Guard from Glaz (Microtex) but I noticed it made my windshield form...
Hydrophobic Glass Treatments
