Page 475 of 479 FirstFirst ... 375425465471472473474475476477478479 LastLast
Results 4,741 to 4,750 of 4790
    May 2010
    #4741
    After you posted this, it got me thinking of my hatch. Lately, I noticed a loss of power & a wooshing sound when the accel pedal is pressed hard. Also noticed a lot of smoke. Happened for the past week or so. It runs well except when I have to depress the pedal hard or when I cruise at more than 120 kph. Been thinking of getting it checked & get egr cleaned since it seems like it lost it’s mojo. The other day, the CEL lit up so I brought it to the casa. They diagnosed a leaking intercooler hose. I got that changed & had the engine decarbonized as well. It now runs like new again. The car is logging 184k kms already in the 6 years I’ve owned it.
    Wow, 184k Kms...not bad at all. Goes to prove that with proper maintenance and care, these “bulgogi” cars can really go a long way.
    How much did the repair cost you?
    How long did it have to stay in the casa?
    Mar 2018
    #4742
    Anybody here tried lifting your accent to increase ground clearance?
    Sent from my SM-G975F using Tsikot Forums mobile app
    May 2015
    #4743
    Hi. Magseek lang ako help if normal lang ito sa car namin. May Accent 2018 CRDI MT kami. And may napapansin akong tunog while pressing the gas pedal. May hangin akong naririnig sa engine bay. It's not the turbo, kasi 1.5k-2k rpm ko siya naririnig. Kahit dampi lang sa silinyador naririnig ko siya lalo na kung open yung hood. Baka blow-off valve? Not really sure. Kasi first time our family to own a Korean car at diesel pa.
    Sana may makatulong kung ano yun. Ayoko sana dalhin muna sa mekaniko. Inputs muna sa ngayon TIA po.
    Sent from my Redmi Note 8 Pro using Tsikot Forums mobile app
    #4744
    Quote Originally Posted by johann123 View Post
    how long has the car been with you?
    how long has the unusual sound been there?
    i don't have an accent,
    but i gather, it should not be difficult to pinpoint the source of that unusual sound, if you or an associate were to stand beside the open engine bay with ears wide open, while someone steps on the pedal...
    i'd also check the engine air intake system. the air filter... the air filter housing...
    something might be loose or "irregular"..
    May 2015
    #4745
    but i gather, it should not be difficult to pinpoint the source of that unusual sound, if you or an associate were to stand beside the open engine bay with ears wide open, while the other steps on the pedal...
    Nacheck ko na doc. Naka lock naman po yung air filter box. And wala naman akong nakita or nakapang lose sa air system.
    May 2015
    #4746
    Try ko na lang mamaya doc. Mas madali nga kung may katulong [emoji28] Guessing game e. Thanks for the reply. Will check it kapag maliwanag na.
    #4747
    Merton din along Accent, 2014 CRDI. Nangyari sakin noon yan. Check mo intercooler hoses mo, Baka may but as. Dalawa yun.
    Feb 2005
    #4748
    May butas ang hoses nyan sa turbo/intercooler Nangyari yan sa Getz Crdi namin dati
    May 2015
    #4749
    Tried to look sa connections ng intercooler. Is this normal? Yung fitting ng rubber hose? img_20210118_111158.jpg
    Jan 2008
    #4750
    need to lift or see underneath to check for hose leaks.. baka may portion na biyak yan..
    also walang blow-off valve yan kasi wala naman throttle plate yung engine like sa gas engine.
Hyundai ACCENT Hatch CRDI 1.6
