Results 4,741 to 4,750 of 4790
June 6th, 2020 08:47 AM #4741
- Mar 2018
- 263
July 18th, 2020 10:45 PM #4742Anybody here tried lifting your accent to increase ground clearance?
Sent from my SM-G975F using Tsikot Forums mobile app
- May 2015
- 146
January 18th, 2021 01:09 AM #4743Hi. Magseek lang ako help if normal lang ito sa car namin. May Accent 2018 CRDI MT kami. And may napapansin akong tunog while pressing the gas pedal. May hangin akong naririnig sa engine bay. It's not the turbo, kasi 1.5k-2k rpm ko siya naririnig. Kahit dampi lang sa silinyador naririnig ko siya lalo na kung open yung hood. Baka blow-off valve? Not really sure. Kasi first time our family to own a Korean car at diesel pa.
Sana may makatulong kung ano yun. Ayoko sana dalhin muna sa mekaniko. Inputs muna sa ngayon TIA po.
Sent from my Redmi Note 8 Pro using Tsikot Forums mobile app
- 52,697
January 18th, 2021 01:11 AM #4744how long has the car been with you?
how long has the unusual sound been there?
i don't have an accent,
but i gather, it should not be difficult to pinpoint the source of that unusual sound, if you or an associate were to stand beside the open engine bay with ears wide open, while someone steps on the pedal...
i'd also check the engine air intake system. the air filter... the air filter housing...
something might be loose or "irregular"..Last edited by dr. d; January 18th, 2021 at 01:49 AM.
- May 2015
- 146
January 18th, 2021 01:51 AM #4745Nacheck ko na doc. Naka lock naman po yung air filter box. And wala naman akong nakita or nakapang lose sa air system.
- May 2015
- 146
January 18th, 2021 01:53 AM #4746Try ko na lang mamaya doc. Mas madali nga kung may katulong Guessing game e. Thanks for the reply. Will check it kapag maliwanag na.
January 18th, 2021 06:57 AM #4747
Merton din along Accent, 2014 CRDI. Nangyari sakin noon yan. Check mo intercooler hoses mo, Baka may but as. Dalawa yun.
January 18th, 2021 07:58 AM #4748
May butas ang hoses nyan sa turbo/intercooler Nangyari yan sa Getz Crdi namin dati
- May 2015
- 146
January 18th, 2021 12:12 PM #4749Tried to look sa connections ng intercooler. Is this normal? Yung fitting ng rubber hose?
- Jan 2008
- 4,726
January 18th, 2021 12:17 PM #4750need to lift or see underneath to check for hose leaks.. baka may portion na biyak yan..
also walang blow-off valve yan kasi wala naman throttle plate yung engine like sa gas engine.
Suzuki JIMNY [merged threads]
