Results 11 to 13 of 13
- Jan 2019
- 18
March 5th, 2021 10:31 PM #11Hi mga sirs.
checking ako now. i came from 2013 Elantra. so far wala nmn ako prob when it comes to AC prob.
is there a technique kaya specially for tucson diesel to check.?
- Nov 2019
- 960
March 6th, 2021 01:33 PM #12Try to drive it during noon at tirik ang araw.
This will let you check if malamig ba AC nya at hindi ba magdegrade lamig nya during running or idling.
Don't be convinced na dahil tirik ang araw kaya hindi masyado malamig.
Malamig ang AC ng Tucson if walang problema sa AC system (AC systems cleaned, new cabin filter, AC Compressor has no defects).
And also, pwd mo naman pa check sa AC shop if okay ang compressor which usually libre lang.
They will just remove the rubber tubing while naka ON ang AC.
From there, bubuga ng black oil yung tube if defective na AC compressor.
Bigyan mo nalang ng tip yung mechanic afterwards.
March 6th, 2021 11:54 PM #13
For the AC, once you open it with Max A/C, within a minute dapat malamig na agad ang buga. Run the engine for 5-10 minutes and dapat malamig during that time.
1st magnetic clutch problem of my 2010 tucson was replaced under warranty. Then nasira again at 7-8 years old and cost 3.5k to replace c/o mang Danny. Not too bad.
Kumalampag suspension ko after 7 years and had bushings and some linkages replaced for about 7k sa Velocity.
Kahit daily-driven 2011 Grand Starex ko kumalampag after 6 years and repaired din for 7k.
Not too bad din for their age.
Thank you!
