Results 1 to 9 of 9
May 17th, 2011 10:25 PM #1
guys need your opinion with our GS Crdi
BACKGROUND
GS - 50K Odo na, June 2008 nakuha unit. huling na change oil 30K using fully synthetic, laging long drive dahil provincial used.
GS namin CHECK ENGINE ngayon. pag paabante, hindi o hirap umabante, kelangan diinan talaga para umabante kahit papano (kahit patag pa ang daan). pero pagpaatras, walang kahirap hirap. hindi namin madala sa CASA dahil sa reason na yan.
Iniisip ko dahil hindi na change oil ng matagal kaya nagkaganyan o nag check engine pero hindi ako sigurado
ano tingin niyo problema?
- Jul 2009
- 3,604
May 18th, 2011 08:12 AM #2Paatras, walang kahirap hirap pero kapag paabante, no power?
Sounds like a transmission issue?
May 18th, 2011 08:31 AM #4
Bigla na lang bang nangyari iyan, bro.?
O, may mga tell-tale signs na magkakaganyan?....
13.1K:bike:
May 18th, 2011 10:39 AM #5
*crazy boy
hindi ako sure kung napalitan ng CASA yun fuel filter nun 30K. pero kung tama pagkakaalala ko, hindi yata napalitan.
*CVT
no tell signs eh, bigla nalang. mag wawashing ng sasakyan yun driver, biglang check engine na tas hirap na umabante. pero sabi ng driver, yun paatras, normal daw talaga. yun abante lang.
hanggang maari kasi ayaw namin pa tow papuntang casa para makatipid, mahal kasi ng singil sa towing service eh
May 18th, 2011 08:03 PM #6
sir baka may nabasa lang na sensor. try nyo din po muna i disconnect ung baterya tapos connect ulet
May 25th, 2011 05:38 PM #9
UPDATE:
kakatawag lang ni wheels EROD, walang problema transimission, na clear daw sa "COMPUTER" kung may OBDII scanner ako natanggal ko siguro yun hahaha! wala pa sanang gastos
Pero sinubukan ko ireset ECU before dalhin hindi nawala check engine eh
chineck nila transmission, wala daw problema at sigurado sila na wala according to mike.
pero tatanungin ko parin what causes the error o check engine, pag kuha ng unit bukasLast edited by c_cube; May 25th, 2011 at 05:53 PM.
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
