Results 11 to 20 of 22
November 12th, 2011 04:44 PM #11
100K give or take 10K in a span of 2 years mga connected sa ondoy ang sira (wala yun turbo problem). Mura padin vs a new/2nd hand ride. Pati ito yun kotse na kaya kami na pa believe sa hyundai sobrang tipid na sobrang tulin. Yun sa ondoy after getting the water out of the engine one click start ito.
November 12th, 2011 11:10 PM #12
Can't find the link. I know it's between 30-50k... might be closer to 50k now... but if you can get a brand new Hyundai turbo for 50k, hell... go for it.
But have your car diagnosed first... rattling might be a loose connection or hose... usually a blown turbo is a screeching thing...
November 13th, 2011 01:28 AM #13
sir dito sa caloocan 4th ave may mga turbo specialist. maganda if napa check nyo din libre diagnose naman sila...
November 13th, 2011 10:27 AM #14
kaya yan DIY. ang mga bearings nyan di naman press-fit, puro bushings saka thrust bearing lang yan di mo need special tools. torque wrench w/ deep socket saka bench vise lang need mo. kelangan mo lang tandaan ano orientation ng mga bushings since pag baligtad ang orientation tirik agad yan.
as for balancing, balanced na ang turbine and comporessor nyan nung inassemble sa factory so no need for balancing, panloloko lang yang need ang balancing palibhasa di mo naman nakikita na binabalance nila so icha-charge ka for balancing kahit di ginawa at di naman needed. basta walang tama yung turbine di na need ng balancing. at pag may tama na yan pati na yung turbine shaft palit na yan di mareremedyuhan ng balancing yan.
- Jun 2008
- 1,741
November 13th, 2011 03:47 PM #15
November 14th, 2011 12:49 PM #16
CASA wont allow owner brought parts. Turbo cost around 77+ sa casa. Wala pa vat. :P
I'll try to check for loose connections muna sa piping.
Nakahanap na ako. alam nyo yun sa blumentrit?
November 28th, 2011 04:34 PM #17
OK na. I've been using it for 2 weeks. Got the turbo repaired. spent 28K. Sumabog yun impeller ko. Parang mas noticeable yun turbo lag now vs before parang turbo kicks in at a higher rpm. OK lang. mas matipid kung ganun. Thanks!
- Jun 2008
- 1,741
November 28th, 2011 04:46 PM #18
November 28th, 2011 05:18 PM #19
wala sa akin yun parts sir sorry. naiwan sa shop. I have no idea na din kung which side is which hindi na ako ganun ka technical. Alam ko kung saan side yun exhaust and intake, pero kung yun compressor and turbine pareho lang meaning sa akin nun eh. Pati baklas na ng nakita ko. Pati i don't know na impeller name nun. Nalaman ko lang sa mechanic and after goggling it. Well if it helps, ubos yun fins ng impeller and before i took it in may rattling sound yun turbo.
Sorry ha. I'm as uninformed as christopher lao.
- Jun 2008
- 1,741
November 28th, 2011 05:53 PM #20
Whatever's free sa casa, usually 3M but last car I bought which is 8 months ago ang dree eh vcool ...
