Results 1,701 to 1,710 of 1710
November 17th, 2014 05:45 PM #1701
Probably as the newer models have had their engines changed to 1.2 or diesels. The 1.4 owners went quiet, probably just accepted the fact that the engine noise will probably be there for the entire lifespan of their units (myself included), with lots of ways to lessen it, but none to eliminate.
December 9th, 2014 09:56 AM #1702
- Aug 2015
- 25
August 16th, 2015 01:21 PM #1703Nanyare na sa akin nung isang araw ko lang na experience sa hyundai accent 1.4 2011 manual ko, after pms ganun pa rin ang tunog nya, para kang may roleta sa engine mo, obserbahan ko lang raw muna kc automatik naman sya nag aadjust ang valve pag ganun pa rin balik ko raw sa knila
- Aug 2015
- 25
August 27th, 2015 06:36 PM #1704Guys ang latest news sa car ko. My car was blown up! Basag ang block mula oil filter at kita na rod sa laki ng biak. ****** inang hyundai yan hugas kamay sila na hindi raw nila papayagan ilabas ang kotse pag may knocking. Ang mali ko naniwala ako sa verbal agreement na titino sya! Wala talagang kwenta ang hyundai specially yang hyundai shaw!! Alam lang mag change oil ulul!!!
September 8th, 2015 01:31 PM #1705
- 52,731
September 8th, 2015 01:55 PM #1706- - - - - - - - - - - - - - - - - - - - - -
why don't you guys band together and collectively accuse hyundai of defective product? if someone in authority sees so many similar cars suffering from the same catastrophic problem, someone in authority will take notice and do something...
you will probably get a more favorable response as a group, compared to individually cursing the dealer..
and if and when the case goes to court, you will be in a better position to win..
just a suggestion, from an un-interested party.
- Sep 2015
- 2
September 14th, 2015 12:55 PM #1707
- 52,731
September 15th, 2015 05:10 PM #1708depends on what type of repair you are willing to settle for.
there's the "pukpok, masilya, at pintahan lang yung damaged part".
then there's the "paint the entire door panel". also the adjacent panel(s).
you can get by with as little as 2-3K for the former... even less if your pintor/latero is your best friend.
September 15th, 2015 09:16 PM #1709
So how's your accent now? Mine (1.4 AT) is at 50k already. It has been out of casa since 2nd yr (I think, forgot seems like ages), just doing oil change at 2K a pop every 5kms (every 6 months). No engine wash done since day 1. No major repairs but 4 tires been replaced already. Aircon still very cold and has not received any cleaning at all. No noticeable change in power. My shocks are still soft (I failed to get it replaced during the 1st year warranty).
I still hear the engine knock every now and then. I drive aggressively most of the time due to my work time (5am) so that might have helped. Gas is always Shell Fuelsave.
BTW, re: shocks, do you guys know of a replacement for it that is stiffer than stock?
- 52,731
September 16th, 2015 01:12 AM #1710- - - - - - - - - - - - - - - - - - - - - -
but what is the cause of that engine knock?
at alfie_marc... dalhin mo na sana sa DTI ang kaso mo. mukhang walang makakamit yan kahit i-post mo sa lahat ng threads dito..
we are just audience.. we are not the decision-makers of hyundai.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
