Results 11 to 20 of 1841
September 6th, 2009 01:18 PM #11
September 7th, 2009 08:21 AM #13
I was checking out some rides with HARI over the weekend, and the SA was telling me that what they're offering here will be a 7-seater....
8601:matrix:
September 7th, 2009 08:39 AM #14
It seems too small to be a 7 seater, tignan nalang natin if it arrives...
September 7th, 2009 09:11 AM #15
- Sep 2008
- 98
September 7th, 2009 11:32 AM #16Nice! Hope that they will be priced slightly higher the current Tucson's and not in the montero/fortuner/forester range..pero malabo
Wonder how they will make it a 7 seater, seems too small for it
September 8th, 2009 01:20 PM #18
The Hyundai ix35 development team moved away from the two-box off-roader look in favor of a sleeker, more reformed profile while aiming for a roomier cabin, extra storage capacity and fuel economy leadership.
Hyundai's new "fluidic" design language finds confident expression in the sweeping, gently curved lines of the Hyundai ix35. The hexagonal grille previewed on the Hyundai ix-onic concept at the 2009 Geneva Motor Show moves into mass production on the Hyundai ix35, a defining look that will serve to unify the family of future Hyundai products. To achieve the desired dynamic and sporty image, Hyundai ix35 gets an aggressive belt line coupled with a low-to-the-ground feel which is enhanced by the optional 225/55 R18 wheels.
The interior lines echo the dynamic flow of the sheet metal. For improved comfort, the designers have carved out extra legroom and headroom (whilst lowering the overall height of the vehicle). The feeling of spaciousness in the cabin is further enhanced by the new dual-panel panoramic sunroof, benefitting front and rear passengers. The center panel can either tilt open or can open completely by sliding up and over the rear panel.
The gauge cluster - with blue backlight - borrows Supervision technology from the Genesis sedan to display key information with crystal-clear clarity and minimal eye stress.
The Hyundai ix35 rides on a 2640mm wheelbase which is 10mm longer than the outgoing Hyundai Tucson. At 4410mm and 1820mm, it is also longer and wider than its predecessor (by 85mm and 20mm, respectively) greatly improving the interior cabin space but the overall height of 1660mm has been lowered by 20mm without affecting headroom.
Greater travel in the front seat adjustment gives more legroom and headroom for taller drivers. The centre console box has been enlarged to 6.2 liters for more storage. In addition, the height of the rear cargo screen has been raised for extra capacity and a small storage binnacle has been added in the rear cargo area.
To further broaden its appeal, Hyundai ix35 will get the newest fuel-efficient engines and six-speed manual and automatic transmissions. Western European customers will be offered a choice of two thrifty and clean-burning petrol engines: the Theta-II 2.0 rated at 166ps and 20.1kg.m of torque which emits just 178g/km (2WD MT) of CO2 and the Gamma 1.6 GDI delivering 140ps and 17kg.m of torque, available from November 2010, which delivers only 158g/km of CO2. This 1.6 GDI engine will be available with ISG stop-start technology, further reducing CO2 to just 149 g/km.
The European diesel lineup includes two all-new engines: the R 2.0 and the U-II 1.7, which will be available from November 2010. The R 2.0 will come in a choice of two outputs: high (184ps/40kg.m) and low (136ps/32kg.m) producing CO2 emissions of just 165g/km (2WD MT) and 158g/km (4WD MT), respectively. The U-II will have a rated output of 115ps with 26.0kg.m and will have class-leading CO2 emissions of just 149 g/km (2WD MT) when equipped with ISG. To achieve Euro-5 emission compliance, the R is fitted with a close-coupled diesel particulate filter plus highly efficient exhaust gas recirculation with by-pass valve.
Six-speed manuals are standard with both diesels while the R will come with the option of a six-speed automatic. Hyundai's all-new six-speed automatic transaxle helps the company meet its goals of improving fuel efficiency and reducing CO2 emissions. Shifts are silky-smooth with an option of sporty-type, manual shifting through the Shiftronic which is also new to the Hyundai ix35.
In addition to the new fuel-efficient engines and transmissions, the Hyundai ix35 features a number of other innovations which contribute to lower operational costs. Nestled between the speedometer and tachometer, the "ECO" coach is a new feature designed to promote fuel-saving driving habits. In the manual transmission version, an icon on the LCD trip-ometer screen begins to flash when the optimum gear shift point is reached. The automatic uses an "ECO" icon backlit by LEDs with either the red, white or green LED lighting up in accordance with driving behavior. Fuel savings in the range of 15 to 17 percent are attainable with the automatic "ECO" coach and 7 to 9 percent with the manual.
The multi-link rear suspension was adopted not only for its superior ride and handling characteristics but also because of its compact design which minimizes intrusion into the cabin creating extra space for passengers and cargo. Tried and true Macpherson struts are employed for the front suspension set-up.
Extensive work was done to isolate sounds and eliminate vibrations. Hyundai ix35 is discernibly quieter both at highway speeds and at engine idle. Booming noise is reduced thanks to a sub-frame dynamic damper while the rear luggage area gets extra soundproofing to isolate exhaust sounds. Road noise has been minimized by improving stiffness in the front and rear struts, rear trailing arm and the spring sheet.
The body shell structure is engineered to the very highest standards of safety: In crash safety tests conducted in-house Hyundai ix35 scores a five-star rating in Euro NCAP testing for both frontal and side impacts. The entire body shell has been made stiffer and lighter thanks to its more extensive use of ultra-high tensile strength steel.
In a panic braking situation, the emergency flash signals are automatically triggered thus reducing the risk of rear-end crashes. Active headrests are triggered by the pressure of the seat occupant's weight on the backrest, the headrests automatically moving upwards and forwards to help prevent injuries to head, neck and upper body.
In addition to optional 4WD capability, Hyundai ix35's CUV credentials are strengthened with two new safety features: Hill start Assist Control and Downhill Brake Control which promote safer travel up and down steep slopes.
For safer maneuvering in reverse gear, a rear-view camera has been added, which operates in conjunction with a 3.5-inch color LCD built into the rear-view mirror. Smart-Parking Assist uses the rear-view camera to provide a graphical grid overlay to safely guide the driver into the parking spot.
Other new features include:
- Push button start with smart-key proximity sensor
- Manual tilt and telescopic steering wheel
- Steering wheel-mounted audio remote control
- Air-conditioned, cooled glove box
- Low rolling resistance tires for 16" wheels
The Hyundai ix35 will be built in three factories on two continents. Mass production of the Tucson started at the Ulsan factory for the Korean domestic market in September. In November 2009, the Ulsan plant will begin production for North America and the general market (all countries outside of EU and greater Europe).
The Kia Motors factory in Zilina, Slovakia will build the Hyundai ix35 starting in the first quarter of 2010 (R engine and Theta-II) and greater Europe in the second quarter of 2010. The Hyundai ix35 will also be built by Beijing Hyundai to meet demand in China.
- May 2009
- 10
September 10th, 2009 12:47 PM #19What I like about Hyundai is that they've come a long way from making the Korean Pinto to a very desired, dependable, car. They seem to steal bits and pieces of design from other premium cars like Mercedes, BMW, Lexus, and smash it all into one vehicle. That seems to be a good niche for them. As far as real innovation goes, they're not going to be winning any firsts, but maybe you don't have to do that to be a rising star in the auto world.
September 15th, 2009 03:51 PM #20
Ang weird sabi ng isang SA sa Hyundai Manila Bay mga 3 years pa daw from now ilalabas ang tucson na ito. (???????)
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
