Results 8,031 to 8,040 of 8071
September 17th, 2020 10:46 PM #8031
- Jan 2020
- 12
September 24th, 2020 04:18 PM #8032Speaker ba ang pinapalitan pag halos di na marinig yung ticking sound ng turn signals?
- Mar 2007
- 9
October 13th, 2020 11:19 AM #8033May I just ask sirs, how many liters do you I need to bring for an oil change? would you recommend to replace fuel filter as often as replacement of oil filter, mas maganda ba sabay dapat sila? TY po
- Apr 2012
- 3,469
October 13th, 2020 12:21 PM #8034
October 13th, 2020 12:49 PM #8035
- Mar 2007
- 9
October 13th, 2020 02:14 PM #8036
- Apr 2012
- 3,469
October 13th, 2020 02:20 PM #8037
October 14th, 2020 12:53 PM #8038
October 14th, 2020 10:39 PM #8039
1. Disconnect bottom water sensor wiring socket
2. Disconmect top fuel pressure sensor wiring socket
3. Disconnect fuel inlet and outlet hoses. May quick disconnect pareho
4. With 13 mm wrench remove fuel filter pump assembly
5. On a bench, remove old fuel filter from pump assembly using a filter wrench. Pwede din socket or box wrench sa end ng filter, di ko lang alam ang size. Ako nga gamit ko slip-lock pliers lang.
6. Install new filter as per normal (oil the seal, additional 1/2 to 3/4 turn after the o-ring makes contact with the housing, hand tight only.) Install water sensor at the bottom of the new filter.
7. Install back in reverse order
8. Open bleed off valve. Manually pump fuel until there are no more bubbles coming from the bleed valve. Close the bleed valve.
9. Start engine to check.
May youtube yan sir, napanood ko long time ago. Search mo lang hyundai starex fuel filter replacement.
Bibili ka filter sa lazada?Last edited by yebo; October 14th, 2020 at 10:43 PM.
October 14th, 2020 10:53 PM #8040
Eto may bago. Iba lang sequence ng steps nya but same steps.
Hyundai Starex Royale / H1- Diesel Fuel Filters Replacement - YouTube
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
