Results 8,021 to 8,030 of 8056
- 38,404
September 13th, 2020 11:53 PM #8022
+1. If the condenser fans and relays are ok then the most probable problem is low refrigerant charge. Check the pressures. Alternately, check the sight glass, it should have no bubbles. If low then have a leak test done. Shampoo (the more bubbles the better) and a sponge on all the connections. Hopefully it is just a loose fitting and not something expensive (leaking evap or condenser coil) or hard to find leak (compressor shaft seal).
Last, sana naman hindi, worn compressor.
September 14th, 2020 07:13 AM #8023
You also might have rather old refrigerant ... they need to be flushed and replaced every 2-3 years or so ... it's quite difficult to DIY aircon repairs since you need special equipment ... one of those things best done by professionals ...
- Jan 2020
- 12
September 16th, 2020 10:39 PM #8024Thanks sa inputs guys. Will have it checked na lang sa aircon specialist. Btw, san located ang sight glass ng freon? Newbie sa GS.
September 17th, 2020 12:18 AM #8025
- Apr 2012
- 3,347
September 17th, 2020 08:54 AM #8026
September 17th, 2020 09:13 AM #8027
- Apr 2012
- 3,347
September 17th, 2020 09:29 AM #8028
September 17th, 2020 01:23 PM #8029
- 38,404
September 17th, 2020 01:26 PM #8030
the guy who did our car, drilled a small hole thru the double-walled panel and pulled the sunken...
Paintless Dent Repair
