Results 7,961 to 7,970 of 8071
June 21st, 2020 05:45 PM #7962
June 21st, 2020 08:52 PM #7963
Na biktima kasi ng malalim na lubak last December sa Andaya highway yung left wheel ko.
Tapos dun na nagsimula yung parang may umaalog sa engine bay.
Pinatingnan ko last week , yung engine support at ibang bushing ang tingin nila na papalitan.
By schedule yung Hyundai casa, puro PMS inuuna, kaya sa Bosche service center ko muna dinala.
2015 model ang unit ko.
June 27th, 2020 10:17 PM #7964
I went to RoadFit banawe yesterday and bought HiQ brake pads. Malaki din difference ng price from their Lazada store to the physical store price. The front severe duty pads are priced at P1850 in Lazada while it is only P1700 at their store. The rear pads are priced P1140 in lazada while at the store it is P990. Add to that shipping cost.
At mas malaki tipid compared to casa! I'm guessing P3-4k for front pads alone, plus labor.
Replaced the pads today. 1mm na lang kakayod na yung warning tabs. Odo is at 20,270 km. Labor cost = zero!
July 13th, 2020 10:00 PM #7965
You are right doc! I checked the battery voltage was only 12.6V. Anyway this made me decide to order a smart battery charger. Lo and behold, the charger indicated that the state of charge was only 20%!!!
I will need to ask the casa if they can adjust the charging voltage when i go for pms maybe next week.Last edited by yebo; July 13th, 2020 at 10:03 PM.
- Jan 2008
- 4,726
July 13th, 2020 10:30 PM #7966charging voltage of the alternator? it is already controlled with 13.8V to 14.2V range by an IC.. maybe the battery is deteriorating loosing its ability to hold charge. if you have smart battery charger, try to use its RECON mode or REPAIR mode. In CTEK charger, it will charge the battery at around 15V for a time, therefore it is recommended to remove the battery from the car.
or its also possible that the alternator is not giving the 14.2V max to fully charge the battery.
- Apr 2012
- 3,469
July 14th, 2020 11:08 AM #7967
July 14th, 2020 11:17 AM #7968
Pangit yung regular HiQ for me. Maingay at andaming dust. Baka mas maganda yung higher end nila, yung Hagen.
Tingin ko Hagen yung nakakabit na OEM sa KDM GS namin. Ceramic and low dust.
July 14th, 2020 01:05 PM #7969
Same ingay ng factory installed pads, less dust. Bagong kabit pa lang e wala pa 500km tinakbo. I will know kung mabilis magwear ang rotor maybe after 10000 km pa. Yung old pads nasa 0,5 ~ 1.0 mm kinain sa rotor (more on front, less at rear) so pag pm ko ng 30k km icompare ko.
July 14th, 2020 01:08 PM #7970
Re: battery. After charging for 10 hours with the charger the battery voltage is now at 13.8 volts, so up by 1.2volts from yesterday. 1 click start na ulit.
I will try to use the battery repair function this weekend.
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
