Results 7,951 to 7,960 of 8071
- 52,731
June 10th, 2020 11:36 PM #7951
June 11th, 2020 11:06 PM #7952
June 17th, 2020 12:09 PM #7953
June 18th, 2020 12:08 PM #7954
Got the shipment from Lazada 2 days ago for power sockets. Installed 1 each on the C pillars. Di na magaagawan sa 2 meter usb cable mga chikiting pag long drive
Sorry can't post pic, something wrong with my tsikot. Basta dun siya sa C pillar, yung plastic moulding na between upper and lower, madaling tangalin may 4 lang na clips. Just peel off the rubber seal on the door then pull. Then you can use a circular saw/hole saw to cut the hole. Pwede din yung drill bit for door lock bolt pero need to make bigger. Then wire it up to the fuse box and connect with fuse tap.
- 52,731
June 18th, 2020 12:26 PM #7956
- 52,731
June 18th, 2020 12:37 PM #7957
June 18th, 2020 11:51 PM #7958
- Jul 2009
- 2,618
June 19th, 2020 01:26 AM #7959
June 19th, 2020 07:54 AM #7960
Anyone here changed the engine support of their GS?
Ilang kms or years before you change the engine support ?
high idle RPM at engine start
