Results 1 to 5 of 5
- Oct 2014
- 37
December 6th, 2014 06:12 PM #1I recently had DLAA fog lights installed for my 2006 Honda Civic and had the bulbs replaced with HIDs. And just today after I parked, I noticed there's condensation inside the right fog light. I'm not sure how long the condensation was there.
I understand the obvious physics that when cool air touches a warm or hot surface, condensation forms etc etc. But interestingly enough, I haven't used any of my lights today causing the lenses to be warmer and it hasn't rained in the past few days. Coincidentally though, I noticed the minor moisture buildup when I arrived home after getting my car washed. Might there perhaps be something wrong with the seals? It baffles me that there's already something wrong when it's barely 3 months old. Or it might just be a factory defect? *shrugs*. What do you guys think? To what extent can condensation be considered normal? Or should I have it checked asap?
I'll probably update after a few hours to see if it disappears. If not, I'll just crawl into a corner and weep haha joke.
- Jul 2009
- 3,604
December 6th, 2014 06:30 PM #2My guesses:
1. Presence of moisture during install or original manufacture.
2. Seal has already worn due to old stock (check date of manufacture, that thing must be a few years old).
3. May not have been sealed in the first place.
In all three scenarios, looks like you'll need to do a reseal of some sort.
For all our vehicles, there has never been any condensation inside the headlamps/foglamps.
- Oct 2014
- 37
December 6th, 2014 06:44 PM #3Thanks for the advice! If that's the case, I'll get the fog lights checked then. It was peculiar that only the right one had condensation. For the resealing, what seals are available? Are there commercially available o-ring type seals? Or do I have to have it resealed with some sort of silicone solution?
- Jul 2009
- 3,604
December 6th, 2014 07:07 PM #4Not sure about the actual resealing process/what stuff are needed as I have never encountered this problem before. Maybe some of the other forumers can help out. If the shop where you got it from is close by, you might as well have it checked.
Even if the shop say it's 'normal', there has to be a remedy for it..
- Oct 2009
- 2,271
December 7th, 2014 03:46 PM #5DIY
baklasin mo ung foglamps tapos bili ng silicon gasket.saka mo lagyan ung part kung saan may rubber gasket para lumapat mabuti at ma seal ung mga portion na umangat,pati ung butas na sinuutan ng wire may lagyan mo nadin para sure.
pag pinabayaan mo yan mababakbak ung pinaka chrome ng foglamps mo..
The Corolla Cross's interior, even on the GR variant, doesn't come close to the CX-5 or even the...
All New Toyota Corolla Cross
