Results 51 to 59 of 59
November 9th, 2009 07:35 PM #51
as i read my brochure files, ang 09 city and jazz ay drive-by-wire. so may throttle sensor yan.. baka dun ang defect...
November 10th, 2009 07:28 AM #52
November 10th, 2009 07:39 AM #53
hehehe....so thai quality is above philippine quality? magkakaalaman to pag punta namin sa antipolo via sumulong puno kami nyan at kapag nagkabitinan sa pagahon sa part ng valley golf...
sobrang dami na electronics and sensors, di na pwedeng sabihin agad na "driver-error" kung bakit "nabibitin" yang city na yan... 1.3MT pa...
November 10th, 2009 12:17 PM #54
Definitely sira ito. She should get a lawyer to help her get what is right for her.
I've driven the 1.3S AT of this model and it's pretty okay. Even fully loaded, the AT version can go up to 180kmh (the fastest I've tried so far at SCTEX).
- Mar 2006
- 6
November 20th, 2009 02:06 AM #55
November 20th, 2009 12:12 PM #56
Hi All! What happened na kaya dun sa unit nung friend ng TS?
I just can't believe me nakalulusot sa QA ng Honda...
Ang ayoko dito yung dinidismiss kaagad yung problem ng customer e...
November 22nd, 2009 10:00 PM #57
I think 17 deg uphill is not so steep. Talagang may problem yung 1.3 na un. Bka stockup yung brake pads nia kaya may nangangamoy. Anyway, Ung Ford Laser '82 1.3 ko nga nakkaakyat pa ng People's Park,e. Ung city1.5 ko nasubukan ko sa 45deg (with 1 passenger) 1st gear, rpm nia is 1500 lng.
- Jul 2009
- 2
November 25th, 2009 04:06 AM #58totoo maraming lemon ang city 09. I was suppose to buy this car but my cousin who works in Honda persuaded me not to buy the model since marami daw lemon. His mom and dad was also suppose to buy 09 city pero he also told them na wag muna since he will not know if lemon ung bibilhin nila. Sya na mismo nagsabi ang daming bumabalik na 09 sa kanila dahil sa ibat ibang problems nito
November 25th, 2009 05:57 AM #59
Hello Sir,
Share ko lang ung sakin. Although I'm driving a Honda Civic '99 I had the same problem nung kagaya sayo... nawawala ung power, tapos minsan parang pump boat na ung tunog ng makina... pero once I restart the engine nabalik naman sa normal. I went to Honda Manila (I suggest you go to this service branch) for a check, hindi nila makita ung problema, and just asked me to keep observing my car. And so I did. After a few months nagiging mas madalas na ung ganitong incident sa oto ko then one morning wala na! kahit irestart ko pa talagang parang pagong na ung andar ng oto so I decided to drive my turtle type civic to Honda Manila and did not turn off my engine para makita at marinig ng service crew ung problema.
They checked my fuel pump = ok
they checked my fuel line = ok
My idle = ok
My spark plugs = ok
My high tension wire = ok
As in lahat ok. Pero since ok ung service tech na kausap ko (His name is Franco) He decided to check the wirings kahit na pag tinignan nila sa kung ano man tawag nila dun sa gadget nila na sinasalpak sa comp. box para makita ung damage e pinapakita normal.
It turned out na may damaged na wirings ung oto ko.. nginatngat ng daga pala!!! kasi naitambak ko un for almost 1yr kasi umalis ako ng bansa...
Anyways since mahaba na ung storya ko, just sharing this incident baka kasi wirings ung problema nung oto nyo at hindi mechanical.
Haba no? sorry hehe! :fetch1:
One more advice... kung July lang nabili ung oto mo qualified ka pa sa 2yrs warranty nyan... dapat sagot nila ung problema ng oto mo... either fix the car or change unit. Wag ka muna gumastos for a lawsuit baka madaan pa yan sa matinong usapan... Baka la lang wenta ung branch na nappuntahan mo... :war: But if all things fail... Sue them! :diablo: :regards:
The Ten Commandments has been a traditional part of the Holy Week programming on local channels,...
Traffic!
