Results 11 to 16 of 16
- Jun 2010
- 321
June 10th, 2011 07:39 PM #11side effect is mas matakaw sa gas .......... ang normal operating temp dapat kulang 1/2 sa gauge, kailan kaba nag pa overhaul ng radiator....baka kasi barado na naman
- Jun 2011
- 43
June 11th, 2011 02:26 AM #12may nabasa ako dito sir about defective temperature sending unit...baka yun ang dapat mong ipa-check first...
- Feb 2010
- 76
June 11th, 2011 05:18 PM #13i have the same problem too. my 1999 civic vti over heated i ended up replacing the thermostat switch because the fan wouldnt turn on. make sure to check the fan motor and the water pump. now my civic overheated again and i replaced the thermostat switch again this is the 2nd time in 2 years. your car will only over heat when idle because when running the air cools it already.
- Jun 2011
- 49
June 12th, 2011 12:39 PM #14thanks for your replies. Yes I already have my radiator overhauled. i was thinking a bad thermo switch. I just replaced my radiator fan motor and overhauled my radiator. My thermostat was already removed. What should be the problem? Any idea?
- Jun 2010
- 258
June 13th, 2011 10:08 AM #15pakiramdaman mo sir kung after driving a few hours na bigla nag 3/4 temp mo.. touch mo kung sobra init makina mo might al well totoo nag ooverheat ka na nga.. pag hindi ganun kainit baka yun temo gauge mo busted or wiring of yun themoswitch, or hindi maganda pagka overhaul ng radiator mo. happened to me..ended buying a new rad
- Dec 2006
- 234
June 14th, 2011 04:38 PM #16
Traffic!
