Results 11 to 15 of 15
January 2nd, 2010 08:00 PM #11
Tanungin mo kaya yung owner. Tawagan mo ... tanungin mo siya kung ano yung engine.
At kung hindi iyan stock, sabihin mo sa susunod na magbebenta siya, ilagay yung engine sa ad niya ... kung modified man.
January 2nd, 2010 08:50 PM #12
You just made a similar thread !
other thread.
LOCK THIS.
And may I remind you ... DO NOT POST IN SMS/TXT FORMAT !
THANKS AND HAPPY NEW YEAR !
January 3rd, 2010 01:43 AM #13
It looks exactly like an ESi engine with an air-filter and headers attached. There's no VTEC solenoid, so it's not a JDM D15B, but it's difficult to tell the difference between a non-VTEC EFI D15 and a non-VTEC D16 without looking at the engine type stamped on the block.
The very fact that it's EFI and non-VTEC means it's probably a local D16 (PH16). The lower-end LXi only came with a carbureted D15.
If you have the registration papers, you can check whether the engine's been changed.
January 3rd, 2010 11:56 AM #14
1) There are many versions of the ZC engine - there's even a SOHC and DOHC ZC (it's the only DOHC D-series). What will determine its VTEC capability is its cylinder head as VTEC is nothing more than a valvetrain technology.
2) One cannot guess what engine resides in that car unless you look at the code stamped on the block. Better if you take a Honda-knowledgeable engine specialist mechanic with you when you inspect the car, because it's very common to have cylinder-head swaps on same-series Honda engines as well (e.g. PH15/D15B non-VTEC bestowed VTEC by swapping in a VTEC head = "mini-me" conversion).
- Aug 2008
- 29
January 3rd, 2010 12:30 PM #15mga sir ito po nkalagay sa engine block or engine number:
ENGINE NO. ZC-6512505
PISTON DISPLACEMENT: 1600
Traffic!
