Results 11 to 20 of 20
- Apr 2008
- 537
December 17th, 2009 10:02 PM #11baka isa sa mga mags mo ay bingkong or disform na kasi magiging manginig din yan kung wala na ito sa tamang shape nito
- Oct 2009
- 75
- Mar 2009
- 35
January 30th, 2010 04:50 PM #13I had the same problem just recently. The whole body of the car seemed vibrating while running above 100 kph. Our trusted mechanic first did the wheel balancing and alignment, but it did not solve it. When he checked again the four tires as the car was lifted, he noticed one at the rear was already oblong or as type 100 described as not perfectly round. He advised me to replace it. So that's what I did... Problem solved... No more annoying vibration at high speeds.
- Mar 2009
- 20
February 5th, 2010 09:39 AM #14Noob question:
Ano po ba ang pagkakaiba ng wheel balancing sa wheel allignment? Paano po ginagawa ang mga ito?
February 5th, 2010 09:45 AM #15
Trying reading this:
http://www.familycar.com/carcare/AlignmentBalance.htm
- Mar 2009
- 20
- Apr 2009
- 33
February 24th, 2010 04:25 PM #18Hi Zup,
all of them are right:
1) wheel balancing
2) wheel alignment (toe, camber, caster)
3) tire condition ....uneven wear
4) check if inner driveshaft is bent
5) check if inner U-joint ball (there three) is missing, thwse are pin type bearing
I hope this can help
Honda OC plus / Salev Racing
June 24th, 2015 09:23 AM #19
Mga sir yung Hyundai grace ko kasi ma vibrate pag tumatakbo na ng 60kph dahil po Kaya sa propeller kasi maingay?
Tsikot Member Rank 3
- Jul 2004
- 1,540
June 24th, 2015 09:33 AM #20Have this problem as well with our car when I changed the tires to All Terrain type. My suki tire shop told me
I might need to have the tires checked for "high speed balancing"
I'll see if this solves the problem.
