Results 21 to 30 of 38
- Dec 2006
- 234
August 5th, 2010 02:26 AM #21
- Jul 2010
- 23
August 5th, 2010 09:50 AM #22Yep sleepsus. ganun na nga. By the way, I'm using NGK spark plugs. Baka mamaya pa tune-up ako then malalaman natin kung yung timing nga talaga ang nagttrigger ng hard starting ko. There is a possiblity that my distributor is set to advance or retard. Balitaan ko kaya. Thanks sa tips and if you have any just keep it coming. More heads are better than one. :D
- Jul 2010
- 23
August 5th, 2010 11:46 PM #23*hyblaxx_24
it seems that resetting (distributor) your timing to advance or retard didn't help resolve the issue of hard starting when your engine is hot. i had to bring my car to a good mechanic with timing tester or sensor to reset the timing. pero ganun parin. tinakbo ko ng approximately 1 hour na naka-on yung lights at aircon. nung pinatay ko sa parking lot, then turn on ulit, hard starting pa rin.
August 6th, 2010 12:32 AM #24
nangyari na din sakin yan....akala ko kc hard starting sya everytime you start the engine...tanung ko lang pag mainit ang engine ayaw mag start or hard starting?kailangan mo p b palamigin bago mo start?yung nang yari sakin di ma start ang engine pag hot kailangan ko pa palamigin kasi sira na yung starter ko.try mo pa check baka stck-up starter k..tnx
- Jul 2010
- 23
August 6th, 2010 07:21 PM #25
August 7th, 2010 02:37 PM #26
August 7th, 2010 05:50 PM #27
try to return it and check..kasi nung nasira starter ko sabi ng mekaniko ng tito ko 2 choices paayus ang starter or paltan ng surplus..ginawa ko pinaltan ko na lang ng surplus just for 2500php sabi kasi ng mekaniko ng tito ko sasakit lang ang ulo ko pag pina repair ko ewan ko lang sa iba na nag rerepair.pag maiinit na b yung engine mo may nararamdaman k b na vibration?parang kapos sa supply?yung before sakin ganun ang nang yari ang replace the ignition coil.tnx..
August 8th, 2010 01:57 AM #28
- Jul 2010
- 23
August 8th, 2010 12:58 PM #29thanks for your responses. i really appreciate it.
if that is ignition coil, me possibility nga. papatingin ko na rin.'yung sakin kasi kapag mainit na ang makina wala naman akong nararamdaman na vibration na tulad ng na-experienced mo. pero sige, papatingin ko na rin. thanks
- Jul 2010
- 23
August 8th, 2010 01:10 PM #30sir, yung oem na thermo switch P1,350 brand new. pero pwede ka makahingi ng discount, simplehan mo na lang. :D labor ko kay rey's free na e. suki kasi ako dun. parts na lang talaga ang binabayad ko. pero malamang, kapag bumili ka ng thermo switch dun sabihin mo baka pwede free na yung kabit since mahal naman yung parts. hehehe. kung marunong ka naman mag diy, ikaw na lang ang magtanggal, madali lang naman yun. gamit ka lang ng 14" or 15" socket. hope it helps. :D
109,606 vehicles were sold in the first quarter of 2024 | TopGear PH
Car Sales Data (2024)
