Results 1 to 5 of 5
- Jan 2013
- 2
January 11th, 2013 12:03 AM #1pls advice...my car honda city lxi '01 ay may humming sound pag natakbo pero nawawala pag inapakan ang clutch...nagpalit na ako release bearing, clutch, at pressure plate...same issue pa rin...thanks in advance!
January 11th, 2013 04:19 PM #2
try u muna din sir ipacheck both wheels at underchassis mo.
- - - Updated - - -
January 11th, 2013 05:12 PM #3
hmmm humming sound? hindi kaya sa tires? either upod na, needs alignment/balancing or just mainly yung brand ng tires is maingay? wheel bearing usually pag high speeds na tapos parang creeking noise ata ang tunog..
January 11th, 2013 05:24 PM #4
Jack up each corner and turn the wheel by hand. If you feel a vibration or if the rotation is not smooth then most probably it's your bearings.
If everything's ok rotate the tires. If the sound disappears or transfers to another corner then it's the tires.
If none of the above it's the tranny.
Edit: re-read the OP. If inapakan ang clutch nag-ok somewhere sa tranny nga yan.
- Jan 2013
- 2
January 12th, 2013 09:52 PM #5thanks sa replies...nag palit na din ako gear oil, same pa din...baka may alam kyo pa-overhaul ng tranny? pls advice...thanks...
- - - Updated - - -
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
