Results 11 to 14 of 14
July 24th, 2010 10:28 AM #11
Try Falken. Made in japan and price is reasonable. I also agree with the guys that to as long as the specifications (particularly size) is the same as your current, it's ok.
I'll put the new tires up front. Traction (particularly FWD vehicles) and when turning is all at front. But nothing beats having all 4 tires new.
- May 2010
- 14
July 24th, 2010 12:44 PM #12Paano po kaya yun sa akin? hindi parehas ang size ng gulong ko sa harap at likod. 195/55/15 sa likod tapos 195/50/15 sa harap. ano kaya epekto non? sa ngayon e ok naman stability ng kotse ko.
July 24th, 2010 02:50 PM #13
Actually there are some rims that require different tire sizes. These rims are commonly called STAGGERED or BROKEN-SIZED. Rear rims are wider than those in front. These are commonly available for european cars; from 16"-up rim sizes. (see photo below)
Note the difference of the front and rear rims. Same diameter but different in specs/offset.
If your 4 rims are equal in size and specs, it's usually the stance of the car that looks odd. But since your flatrate difference is minimal (50 vs. 55 series), I think the vehicle's stance would not look much different.
One setback of staggered or broken-sized rims is that you would have limitation in rotating the tires (tire specs for front and rear are different)Last edited by Benzmizer; July 24th, 2010 at 02:53 PM.
July 25th, 2010 04:55 PM #14
So... have you driven a FWD vehicle with worn tires?
Never had any issues with worn front tires. None. It's harder to accelerate in the rain, but that's preferable to being unstable in braking.
And yes, I've spun a car (in my younger days) and witnessed many spins and near spins due to having worn tires on the rear. Needless to say... hitting a telephone pole side on is much more dangerous than sliding into it head on. And if you have worn tires, you won't be sliding sideways off the road into that pole, you'll be sliding straight down the road.
Even tire manufacturers recommend putting worn tires in front IF you can't change all four at the same time.
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
