Results 21 to 28 of 28
May 15th, 2006 12:16 AM #21
bratski,
just about 40k. if you can, aside from surveying other RV501 users, you might wanna actually try trading-in for them, since you're not happy with your SP70s. they're 6 ply vs the SP70's 4 ply, so i would think they should more than ably handle the punishment. and they look wider than bridgestones of the same size. don't go with the AT tires unless you plan going offroad. you've got less on-road traction and alot more noise because of the aggressive tread. we put grandtrek at tires on our santa fe when it was new, and boy were they really noisy. we eventually replaced them with SP601s. ayun, tahimik.
May 15th, 2006 03:26 AM #22
michelin is the best way to go. just don't get the made in italy ones. pangit ang quality nung gawa duon. na flaflat sila agad. yung sa odyssey ko, ilan beses na palitan ang gulong sa kakaflat.
if Michelin Cross Terrains are available for the CRV size, get that. I'm running 44,000 miles on Cross Terrains, and nowhere near the end (nowhere near half life pa nga yata).
Tsikot Member Rank 4
- 1,842
May 15th, 2006 01:21 PM #23try the special size
28X8.50 R15 Tire by Yokohama
Brand is Super digger
Bigger than your 205/70/R15
will not rub on wheel wells even on a full load
- Aug 2003
- 114
May 15th, 2006 03:42 PM #24Bratski,
I suggest you change your springs to the 5-seater type. As for tires, go for the Michelin Synchrone -- they're great!
That's what I did for my 4x2 CRV.
Them Dunlop RV501s are soft. Will wear out fast.
- May 2006
- 913
May 15th, 2006 10:52 PM #25i had the same problem wit the rv501, like IMm29 said, bout the uneven wear on the front tires,i notice it after 6months of use, and i had it aligned and we actually had to make the settings change to compesate for the outside wear of the tires. but it still wore out the outside more than inside of the tire. so dats y i bout a different type of tire now, its still dunlope. so a side from than problem i really like the rv 501s cus its bigger than most tires wit the same size rating.
May 16th, 2006 01:37 AM #26
thanks guys for all your suggestions
maxbuwaya
I think the supper diggers are a bit larger since the overall diameter is 28". My current sp70's are 215/70 r 15 with diameter of 26.9", this size already affects my mileage and torque
storm,
where did you buy your 4x4 springs and how much?and also the price for the michelin synchrones.thanks
- Aug 2003
- 114
May 17th, 2006 04:56 PM #27I bought my springs from a friend. I can't recall the price anymore because I posted it in the old Honda Club Phils. forum (which is using a temporary board at the moment).
As for the tires, you can check out shops like Roadstar. Their main shop is in Estrella St., San Antonio Village, Makati. They also have outlets at The Fort and Alabang Town Center. I think its around 4-5 thousand/pc.
June 13th, 2006 12:09 AM #28
just to update you guys, I just bought a set of falken landair for the front tires.Medyo ok naman siya and not as harsh as the dunlop sp70e. Its in the stock size of 205/70 r15.Medyo manipis tingnan but quieter. I plan to change the rears to dunlop rv501's
Air Mall or Assembly Grounds * The Rise.
Makati CBD parking
