Results 1 to 7 of 7
- May 2011
- 17
May 20th, 2011 05:15 PM #1Hello po,
Tumatakbo na yung auto for 2 weeks now until i realized yung driver filled tap water sa plastic container para dun sa radiator instead of coolant. May epekto po ba sa airconditioning system ng auto for using pure tap water?
May 20th, 2011 05:31 PM #2
If it's only been a few days and you still have a coolant-water mix in the radiator, it's okay.
Over the long term, using tap water can introduce scale and rust to the coolant system. It's best to use distilled water mixed with coolant in 50:50 or 30:70 (30% coolant) proportions.
May 20th, 2011 07:25 PM #3
I would flush it out with distilled water and replenish it with the correct amount of coolant+distilled water or as indicated in the manual. Use a coolant specific to your car/engine. OEM is best. If you put in the wrong coolant, it may be bad for the pump seals.
May 23rd, 2011 08:17 AM #4
May 23rd, 2011 12:47 PM #5
Use pre-mixed coolant if available. If you need to mix 50/50, use only distilled water as the hard water from the faucet will cause rust inside your engine.
- Jun 2008
- 81
May 23rd, 2011 10:23 PM #7
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
