Results 1 to 3 of 3
- May 2007
- 104
April 5th, 2010 02:08 AM #1question mga bro,
i am scheduled for shock absorber replacement (front and back). worn out na ang shocks sa likod at harap. nag aantay na lang ng budget para mapalitan lahat pero unahin ko muna ang likod.
pag 2 lang ang sakay ko sa likod sayad na ako sa humps at parang bagsak na bagsak na ang oto. tanong ko mga bro, sure ball ba pag nagpalit ako ng shocks aangat ang height at hinde na sasayad?
ang stock springs ba ng oto nasisira at kelangan din palitan over a period of time? ayon sa manual, tuwing kelan ba pnapalitan ang springs at anong indicator na kelangan na ito palitan.
padagdag na rin sa query:
-magkano ang KYB excel G shocks (harap at likod)?
-magkano ang stock / oem springs (harap at likod)?
-magkano naman ang pinaka mura / 'bang for the buck' na lowering spring? (ang gusto ko sana 1 - max of 2 inches drop lang)
-san ok at mura bumili ng shocks and springs (stock or after market lowering springs) aside sa gga suki nating auto supply at banawe?
-lastly, compatible ba ang kyb excel g sa lowering spring na 1-2inches max na lowering springs?
since i'm in a tight budget... here is my prospect for adjustable lowering spring...
here is their link, nakausap ko na seller, mukhang ok naman...
http://quezoncity.olx.com.ph/honda-a...-71143335#pics
-is this ok to be paired with kyb excel g shocks?
-may nakabili na ba sa inyo ng ganito kamurang adjustable springs? ang gs2 ko kasi pwedeng 1 inch lang ang drop, i can even choose to drop it max of 4 inches. tingin ko parang sulit eh. what you think guys?
car is honda esi 95...
salamas!
April 5th, 2010 09:52 AM #3
I didn't know that there were coilover springs that are priced at that range. I thought they'd reach the 5 digit mark, oh well ... maybe it does depend on the brand.
*TS :: The cheapest BRANDED lowering springs that you could find is R1. They're priced at around 5 - 5.5k for a set of four, brand new. However, there are UNBRANDED lowering springs that you could find too, it's priced at around 2.5 - 3k, depends on the seller. The thing that you should look at SURPLUS/UNBRANDED lowering springs is if it's just the original springs with a cut. There are several uncut SURPLUS/UNBRANDED lowering springs that i`ve seen that are priced at around 2k+ for 2 pcs.
Monk-owned R53
