Results 1 to 4 of 4
- May 2011
- 6
June 3rd, 2011 03:19 AM #1mga sirs ive got this problem na kahit i adjust ko po ung menor sa cervo parati below 600 rpm po siya and kapag mag aircon ako, parang mamatay un makina... anu po kayang possible na problem nito and saan po kaya pwedeng ipagawa ito, im located sa paranaque thanks po...
- Dec 2006
- 234
June 3rd, 2011 04:36 AM #2kung hindi madumi or defective na yung IACV mo, may setting procedure yan sa alam ko ....
1) warm up the engine until it reaches normal temperature, wait for the rad fan to automatically turn on and off.
2) disconnect the the wires that plug into the IACV. CEL will turn on*
3) adjust the idle.
4) turn off the engine and reconnect the wires.
5) start the engine and see if it worked.
* if your CEL is still on after this, you may need to reset the ECU.
pero try mo muna pa linis yung TB and IACV, baka madumi lang. Pa check mo na din kung defective.
- May 2011
- 6
June 3rd, 2011 09:08 PM #3napacheck ko na po ung IACV dun daw po ung prob sir, and ung cervo din daw po kailangan nang palitan... salamat po sir, for the mean time nag remedyo lang po muna ako na i adjust ung accelerator ng konti para medyo mataas taas ung idle ng auto... san po kaya ako makakabile ng murang surplus na ok pang IACV? thanks po sir sleepsus...
- Jun 2010
- 321
June 5th, 2011 03:42 PM #4kapapalit ko lang iacv 1k php bigay sa akin sa ckd/sprint banawe first kanto sa old banawe + 2h labor ok na ang flactuating idle ko......... pero try mo munang palinis ang tb at iacv pati fitv narin if ganoon parin palit kana talaga ng iacv same din kasi problem natin........... gawin mo muna yung procedure ni sir sleepsus base idle ata ang tawag ata doon
Suzuki JIMNY [merged threads]
