Results 1 to 10 of 10
October 29th, 2009 07:38 PM #1
Sir, ask ko lang kung mura yung H22A sa 45K pag my transmission 70K? pwede ko ba ipalit sa SOHC VTI ko yun? If ever anu po kaya ang papalitan na mga parts sa pang ilalim ko? TIA
October 31st, 2009 04:13 AM #2
Get the ECU also. Sure it fit on your engine bay, I just dont know exactly how my friend did in his Civic. The H22A is a 2.2 engine DOHC VTEC 220 hp/163 ft./lbs of Torque and it came out from Prelude SiR (JDM). For 70K including the tranny, boy take it, dont ever leave the place or take away your eyes on the engine cause thats a bargain. Here in states it cost like $2,600 just for the engine not including tranny, if you found one.
Just make sure its a H22A SiR S-Spec.
November 1st, 2009 07:08 PM #5
You can't change physics. Also heavy engine would require stiffer springs, which would affect ride quality. Using typical Civic aftermarket springs would just bottom out every time you encounter a road speed bump or a pothole.
I know this because I have a SR20 engine in my Sentra. I had to use very stiff springs to avoid bottoming out my front suspension on every bump I hit.
Something else to consider.
November 1st, 2009 11:37 PM #6
November 1st, 2009 11:56 PM #7
Well, with stiffer springs you'll need to match them with the proper shocks.
You could research a bit on what possible springs and shock could be used for Civics with H22A engine swaps. It might be possible to use stock springs and shocks from another car into your civic which would result in a cheaper cost.
November 2nd, 2009 10:45 PM #8
Doubt Accord stuff will fit... the honda boys might know, though...
I'd go for a mix and match... strongest shocks you can get... stiff lowering springs you can get for the front, with rubber lifters to compress them a bit and make them stiffer, matched with relatively mild suspension in the rear.
- May 2007
- 104
November 3rd, 2009 02:24 PM #9don't forget to upgrade your brakes. sobrang lakas na nyan at kelangan mo ng mas malakas na stopping power. sisibak ng mga SIR yan
- Jun 2009
- 19
November 4th, 2009 02:22 AM #10share ko lang ser...may natanog ako about h22 engine...astig nga daw...problem is hirap daw humanap piyesa non...kasi luma na daw...yun lang ang sabi sakin...
Monk-owned R53
