Results 1 to 6 of 6
- May 2009
- 7
May 12th, 2009 11:49 AM #1hello guys snecya bago lang ako d2... tanong ko lang.. sa 95 esi ko with a ph 16 engine .. kasi kapapalit lang po ng pressure plate, release bearing, saka clutch disk,... kasi feeling ko sliding clutch na... pero.. sa tuwing na tatraffic ako... prang automatc umandar ang kotse nawawalan ng hataw.. ang bagal .. lalu na pag mainit ang panahon like 10AM to 3pm.. pero pag gabi ang ganda ng hataw ... anu pu kaya pedi problema nito salamat po...
- Aug 2005
- 205
May 12th, 2009 05:00 PM #2i don't see any connection with the clutch and the problem. unless sliding ka ulit.
- May 2009
- 7
May 13th, 2009 12:05 AM #3kasi po.. pag na traffic ako sakay 95 esi from 11AM to 3PM... lalu na kung mainit ang sinag ng araw... unti unti po nawawalan ng hatak, ang sasakyan.... 5,000 rpm naka 1st gear 5km/h bilis ko po... gusto ko lang malaman anu po possibleng problem? sensor ba? fuel? any idea? anyone, salamat po....
- Aug 2005
- 205
May 14th, 2009 10:27 PM #5
how's the coolant temp? lumalapas ba sa kalahati? kahit konti lang?
pag sobra init yung engine minsan ganyan. i suggest you have the engine valve clearances checked, too. sa casa na lang, mura lang yun 990 lang.
maganda yung takbo nya pag gabi kasi malamig yung air, mas maganda sa compression ng makina... pag tanghali at nakahinto, nahihigop nya yung init sa engine bay, kaya panget yung takbo. check also the radiator fan and the thermoswitch kung umaandar pa.
May 15th, 2009 03:17 AM #6
If it is happen only when engine is hot or on a hot weather bring your car to any shop to to hook a presure gauge to check your "fuel pump pressure".
agree ako syo. battery dying will be the next owner's problem. kaso the only reason I'm buying...
All New Toyota Corolla Cross
