Page 1485 of 1486 FirstFirst ... 138514351475148114821483148414851486 LastLast
Results 14,841 to 14,850 of 14858
    #14841
    Ok na yung EFB for regular start stop applications. The ones that don't have regenerative braking. One advantage of AGM over EFB is they are totally acid vapor free. EFBs still emit a bit of acid vapor from the vents, regular batteries more so.
    Ok din yung EFB if you hardly use the car. Mas matagal madischarge. Or if you have a lot of aftermarket electric accessories. AGM is even better but ang laki kasi ng price jump vs EFB so hindi sulit.
    AGMs are usually OE for luxury cars like Audi, BMW, Mercedes, Porsche, etc.
    #14842
    same lang yan sir.. mas matibay lang AGM batt compared sa flooded battery.. pero walang magiging effect sa charging if you use AGM battery.. mostly yan ang recommended battery sa mga cars with i-stop feature since the car will utilize the battery more when i-stop is activated (accessories will run on batt)
    Salamat Sir Yapoy! Walang difference sa charging system ang AGM, yon ang hinahanap ko na assurance. And as you said, mas durable kesa sa flooded stock battery. Stay safe po. [emoji3]
    Sent from my SM-G930F using Tapatalk
    #14843
    Thank you for giving me fresh tidbits to digest! So the EFB is mid level between the more expensive AGM and the regular flooded cell batteries.
    Car is matic transmission (no push starts) and the possibility of low battery voltages due to infrequent use (pandemic lockdowns) is real. These 2 factors somehow triggered the planned upgrade to AGM due to its noted voltage retention coupled with its durabilty vs regular batteries.
    But then again, your advice re EFB seems the best upgrade alternative since car naman has no start-stop. EFB cheaper than AGM yet retains most of the latter's characteristics.
    Again thanks to you, Sir, EFB looks like a winner.
    Btw, any ballpark estimates of EFB durability compared to the 3-year ave. life of stock flooded batteries?
    #14844
    Hindi ko na recognize iyong bagong honda city. Akala ko kahapon iyong pre-mmc na 10th gen na civic na simplified or tempered down.
    Mar 2018
    #14845
    Anybody tried replacing rear break light for a 2013 honda jazz? Check youtube and its mostly twist and turn but mine isnt.20220109_130117.jpg
    Sent from my SM-G975F using Tsikot Forums mobile app
    #14846
    Quote Originally Posted by RavenBlack View Post
    whypo?
    what did you do?
    i youtubed, and it looked easy enough.
    my guess is,
    yours wouldn't turn.
    maybe you were turning it the wrong way?
    if things are stuck, maybe a squirt of wd40 will help vastly?
    Jun 2011
    #14847
    Natanggal na ang bulb at bulb holder?
    Mukhang twist type iyong bulb holder.
    Mar 2018
    #14848
    The 2 holes that are open is for the signal light and reverse. I already removed that. The open socket is the one for the break light but the bulb is not connected directly to that socket. You can see a wire going somewhere. I removed the screws and I don't see anything that can be remove.
    Sent from my YAL-L21 using Tsikot Forums mobile app
    Mar 2018
    #14849
    whypo?
    what did you do?
    my guess is,
    Doc, the signal and reverse are the ones that you can twist. In youtube even the break lights is also twist and turn.
    Mar 2018
    #14850
    Brake light bulbs not break [emoji28]. The one that is circled is where the socket comes in but I think the bulb is in the lower circle. img_20220109_134521.jpg
Second Gen. Honda Jazz/Fit
