Results 14,851 to 14,858 of 14858
- Jun 2011
- 1,077
January 9th, 2022 02:47 PM #14851Baka LED brake lights?
Kung oo, alam ko baklas lens via heat gun. Tapos palit ng LEDs.
Si Gary sa HID Retrofit gumagawa yata niyan.
- 52,698
- Mar 2018
- 263
January 9th, 2022 03:06 PM #14853Probably LED na nga, so iba design. Thanks for the replies.
Sent from my YAL-L21 using Tsikot Forums mobile app
May 21st, 2022 10:01 PM #14854
Hello Sirs. Does anybody know the normal operating temperature range ng Jazz GE? Mine's the 2013 model.
Gumamit ako ng OBDII bluetooth adapter and sa Torque app, umabot ako ng 105 celsius nung nag 60kph ako sandali. Nung medyo traffic, nasa 100-103.
Normal ba to or mataas?
No history of overheat pero recently nagpalit ng radiator fan assembly kasi bumigay and nag change coolant/bleed na din.
- May 2018
- 33
May 22nd, 2022 03:59 AM #14855
Sir, similar din na-experience ko sa 2012 Jazz 1.3. Minsan na-traffic ako, umilaw yung temperature icon sa dashboard pero red color (instead of blue during cold start). Ikinabit ko yung OBDII scanner, yung engine coolant temp (ECT) nasa 104 deg celsius. Napansin ko mahina ang ikot ng radiator fan, parang humihinto agad. Kaya pinalitan ko yung fan motor at change coolant na din.
Sa ngayon, ang operating temperature ko ay 85-87 pag relax driving. Pag aggressive driving o kaya pag sobrang init ng panahon, nasa 93-97 ang range.
Base sa naging experience ko, mataas nga yang temp mo. Siguro next mong i-check or palitan yung thermostat and/or radiator cap.
May 22nd, 2022 09:27 AM #14856
Check the radiator fan motor. It may not be working properly or needs replacement.
- 52,698
May 22nd, 2022 11:03 AM #14857i had the same problem with my 1997 sentra.
it was overheating, but i could not find the cause.
i thought my aux fan was fine, as the air volume as measured by my hand, seemed good...
until an old timer mekaniko advised me, "doc, bili ka ng bagong fan motor, and garantisado na mabibigla ka sa diperensya. kung hindi ay ibabalik ko sayo ang pera."
he was right.
May 22nd, 2022 02:35 PM #14858
Oo nga sir Rico hindi din mainit panahon kahapon kaya mukhang hindi nga normal ang ganito kataas. Yup, thermostat and thermoswitch ang next na i-check ko baka dun na makuha. Salamat Sir.
Egan, Doc, kakapalit lang ng fan motor brand new got it from lazada pero mukhang original Honda naman. Yung luma kasi kailangan na pukpukin para gumana. Itong bago walang problem mag automatic and if measuring by hand malakas yung hangin, pero I'm not really sure if normal speed ito. May way ba para ma-measure ang speed nito?
Choosing one would depend on your driving and parking conditions. Do you have your own garage =...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
