Results 14,841 to 14,850 of 14858
August 21st, 2021 05:34 PM #14841
Ok na yung EFB for regular start stop applications. The ones that don't have regenerative braking. One advantage of AGM over EFB is they are totally acid vapor free. EFBs still emit a bit of acid vapor from the vents, regular batteries more so.
Ok din yung EFB if you hardly use the car. Mas matagal madischarge. Or if you have a lot of aftermarket electric accessories. AGM is even better but ang laki kasi ng price jump vs EFB so hindi sulit.
AGMs are usually OE for luxury cars like Audi, BMW, Mercedes, Porsche, etc.
- Sep 2015
- 37
August 23rd, 2021 03:42 PM #14842
- Sep 2015
- 37
August 24th, 2021 03:15 PM #14843Thank you for giving me fresh tidbits to digest! So the EFB is mid level between the more expensive AGM and the regular flooded cell batteries.
Car is matic transmission (no push starts) and the possibility of low battery voltages due to infrequent use (pandemic lockdowns) is real. These 2 factors somehow triggered the planned upgrade to AGM due to its noted voltage retention coupled with its durabilty vs regular batteries.
But then again, your advice re EFB seems the best upgrade alternative since car naman has no start-stop. EFB cheaper than AGM yet retains most of the latter's characteristics.
Again thanks to you, Sir, EFB looks like a winner.
Btw, any ballpark estimates of EFB durability compared to the 3-year ave. life of stock flooded batteries?
Sent from my SM-G930F using Tapatalk
December 17th, 2021 10:28 AM #14844
Hindi ko na recognize iyong bagong honda city. Akala ko kahapon iyong pre-mmc na 10th gen na civic na simplified or tempered down.
- Mar 2018
- 263
January 9th, 2022 02:01 PM #14845Anybody tried replacing rear break light for a 2013 honda jazz? Check youtube and its mostly twist and turn but mine isnt.
Sent from my SM-G975F using Tsikot Forums mobile app
- 52,731
- Jun 2011
- 1,080
January 9th, 2022 02:30 PM #14847
- Mar 2018
- 263
January 9th, 2022 02:39 PM #14848The 2 holes that are open is for the signal light and reverse. I already removed that. The open socket is the one for the break light but the bulb is not connected directly to that socket. You can see a wire going somewhere. I removed the screws and I don't see anything that can be remove.
Sent from my YAL-L21 using Tsikot Forums mobile app
- Mar 2018
- 263
January 9th, 2022 02:41 PM #14849Doc, the signal and reverse are the ones that you can twist. In youtube even the break lights is also twist and turn.
- Mar 2018
- 263
January 9th, 2022 02:47 PM #14850Brake light bulbs not break [emoji28]. The one that is circled is where the socket comes in but I think the bulb is in the lower circle.
