Results 1 to 4 of 4
- Jan 2009
- 10
March 10th, 2009 03:25 AM #1mga sir, pinaayos ko po aircon ko last week kc medyo mahina and hindi masyado malamig especially po sa tanghali. nung una naging ok nmn po pero after ilang days bumalik sa dati and mas worse pa. kung dati lumalamig sya and mararamdaman mo na nag-oon yung a/c ngayon po hindi na. as in mainit yung hangin nya? ano po kaya possible reason kung bkit nagkaganun and is it consider po b n back-job dun sa gumawa ng aircon ko? and at the same time sabi kc ng friend ko, one reason din kaya hindi gaano kalamig aircon ko is because clear po salamin ko and walang tint. wala daw po protection sa direct hit. if magpapatint po ako ano po maganda brand and magkano? thanks po in advanced.
March 10th, 2009 05:20 AM #2
i suggest find out first what you need to cure rather than do it by trial and error. yes, tints improves heat rejection significantly, but if your A/C is blowing hot air even on non-sunny weather, then it's a different story. baka masayang lang tint mo.
i suggest balik mo sa pinagpagawaan mo. ano ba ginawa raw nung dinala mo sa kanila? may tagas ba ung sa freon? pag gabi ba malamig buga ng hangin? malamang compressor issue na yan, and it's best sila ulet pagtroubleshoot mo ng issue.
- Mar 2009
- 5
March 10th, 2009 08:23 AM #3Hindi issue ang tint, pero marereduce ang heat transfer from outside going inside your car. Mas maganda sila rin magtrouble shoot nyan, maaaring may leak na ang shaft seal ng compressor mo or kung may pressure switch man eh di na gumagana try mo tingnan kung may bubbles pa yung filter drier mo kung wala na nag leak na ang freon mo. Maaaring may sira mga hose or d maganda pagkakalagay ng mga fittings. Nangyari na rin sa akin yan buti na lang magaling ang gumagawa ko ng aircon.
- Jan 2009
- 10
March 10th, 2009 09:54 PM #4sir, sa car aircon specialist ko po sya pinagawa and sabi naman po nya walang problema compressor and expansion valve. ok naman din po yung thermostat. ang ginawa lng po nya eh nilinis yung evaporator and ni refill ng bagong freon. pero after ilang days, nwala bigla yung ac. parang hindi n po nag-oon. bka po ibalik ko sya this week or sa friday pag may time kc mas naging worse pa yung situation nung kotse. and regarding po sa tint, siguro kung hindi na lng ako papatint kasi mas gusto ko clear. and totoo po ba na pag naka-aircon eh hindi advisable na ibirit o paabutin man lng ng 6-7 rpm kasi mapwepwersa compressor? thanks po ulit mga sir.
