Results 31 to 39 of 39
- Sep 2016
- 2,275
March 7th, 2019 12:14 PM #31
March 7th, 2019 12:41 PM #32
Napost ko na before
Umilaw check engine light, dinala ko sa kanila for scanning/diagnosis.
Sabe oxygen sensor daw, since casa tiwala na lang diba?
Nasa 13K oxygen sensor
Lucky thing wala available na parts, paid for the scanning na lang.
Called all the dealers nearby, wala talaga available since for order yung piyesa.
Honda Kalookan guaranteed me magkakaron sila in 2 days, so dumating yung sensor.
Bago install nag scan ulit sila, binalikan ako nung SA
Sir nakatipid ka, fuse lang pala problema pinalitan lang namin. Ayun okay na.
Na-hassle lang yung kaibigan ko sa HondaKal since hindi na ako nag down, siya na nag vouch for the order. Ayun nakakahiya kase hindi ko naman kinuha yung ordered na sensor.
Ayaw kasi mag stock nung casa ng mga hindi fast moving na parts to add pricey yung piyesa.
- Sep 2016
- 2,275
March 7th, 2019 02:07 PM #33
June 10th, 2019 04:40 PM #34
LABOUR CUSTOMER 1,106.00
2PX OIL FILTER 454.83
Drain Plug Washer 30.25
SN 0W20 UNI 6X4L 2,763.40
PM KIT 325.00
CS KIT
MISC 338.00
GREASE,PAD(MOLYKOTE M77) 86.44
GREASE,PIN (NIGLUBE RM) 41.78
ENGINE TREATMENT 995.00
Perform [ ] Replace Engine Oil Filter
Perform [ ] Check Suspension mounting bolts
Perform [ ] Check Front/Rear brakes
Perform [ ] Check Air Cleaner element
Perform [ ] Rotate tires (condition,wear,press)
- Oct 2019
- 2
October 24th, 2019 04:02 AM #35New here
I bought a 2nd hand City 2014 and it will be due for PMS by December. Last PMS po was June 2019. It was maintained in Honda Alabang. Should I still consider bringing it there for my next PMS or pwede na ung mga reputable shops outside casa. Hope someone answers po. Thanks!
- Jun 2004
- 1,311
October 25th, 2019 04:10 AM #36If it were me sa Honda ko ipa-PMS. Unless ok lang sayo ikaw mag hanap ng parts at mechanic na maayos na gagawa.
A long time ago mahilig pa ako sa DIY at kung saan saan paayos, pero ngayon na laging busy at pagod sa work ok na sa Honda magpapms, usually sa Honda Greenbelt Hub para ikot ikot muna mall habang service. Pero pag major repair consider sa labas much cheaper parts.
October 25th, 2019 07:58 AM #37
5 years/100k PMS. Pagawa mo na lang sa labas.
October 25th, 2019 05:36 PM #38
October 25th, 2019 05:58 PM #39
My City turning 5years next month.
Casa pa din PMS (Honda Spa) No optionals and minsan yung nirerecommend na dapat palitan na if tingin ko hindi pa naman talaga or pwede ipa move next pms. I now follow mileage (10,000kms intervals)
Wala pa kasi din ako mahanap na reputable shop, mabait mga tao sa Spa and maayos kausap, may SA dun kaibigan ko na din madali makontak pag may concerns.
