Results 21 to 30 of 33
December 28th, 2011 05:51 PM #21
hek hek hek! i am a u.s. a.s.e. certified master automobile technician, a.s.e. certified master medium and heavy duty truck technician. have been wrenching for over thirty years and currently an instructor for technicians for auto dealerships in my place for over twenty years. sorry, not bragging, just answering your inquiry. but thanks.
- Nov 2011
- 79
- Nov 2011
- 79
December 28th, 2011 06:45 PM #23
December 28th, 2011 07:32 PM #24
please knock it off already. back to your dilemma. describe the frequency, the intensity of the noise, the particular conditions when the noise appears and the perceived location of the noise source
- Nov 2011
- 79
December 28th, 2011 08:05 PM #250-60km/h wla pa naman sound na napoproduce, actually sir ganito yung napproduce nya na sound Honda Civic wheel bearing noise?? - YouTube
between 70-80 ganun ung sound na palaks ng palakas
December 28th, 2011 10:33 PM #26
I've already told you it's the wheel bearing...sakit talaga ng CRV gen 1 yan...I've not a certified mechanic but it's up to you if you want to believe me or not...
January 6th, 2012 12:16 PM #28
for better DIY diagnosis, remove the propeller and check if the noise will disappear...
rear differential and propeller of CRV first gen produces the same noise also. in addition, one indication of rear differential propeller going bad is the heavy tok sound during close turning.. my cent
January 6th, 2012 01:37 PM #29
BTW with respect to permanent removal of propeller, that is, 4wd to 2wd, of course you should weight the feature you will be removing from your vehicle vis-a-vis the demand when you needed to use it...
if you're always on a city driving, yes can remove it. no question about it. less maintenance.
but if there will be occasions that you will use it in xpress way during heavy rains, realtime 4wd is very helpful on slippery roads. whereas in rural areas or if you will go to farm where terrain or road condition is not that good, i would suggest not remove it otherwise you should be prepared in leaving you V and just walk to your destination.
the choice is yours... regards
January 6th, 2012 03:44 PM #30
AWD doesn't help at all in the rain on concrete. Since the CR-V is front wheel drive, all AWD does is minimize torque steer from a dead stop. When a crossover or car hits a puddle and starts hydroplaning, the results are the same whether it's AWD or FWD... it gets knocked off line for a short bit, then when the front tires regain traction, the front wheels pull it straight. AWD is only safer in the rain than RWD, where oversteer in slippery conditions is more of a problem.
I've driven all wheel drive, rear wheel drive and front wheel drive vehicles in the rain, and I've also driven examples of all three in the mud and dirt (yay, rally-cross!), where there's almost no traction at all... the only disadvantage of front-wheel drive in these conditions is that if it gets too slippery off-road, it won't accelerate as quickly as AWD. The reaction to driver inputs and oversteer/understeer is largely the same (unless you have a sophisticated torque-juggling center differential and rear differential a la Evo or the current STI).
FWD is more prone to getting stuck in deep mud or sand... But since the CR-V has open differentials and no LSD, you can still get stuck if you're on a split traction surface, if you're on a deeply rutted road or if you allow your momentum to fall too low in the sand.
Suzuki JIMNY [merged threads]
