Results 11 to 20 of 20
- May 2011
- 19
May 28th, 2011 12:06 AM #12try ko muna linisin ung IACV at ung throttle body.pag hindi sya umokay.ttry ko ung sa servo.ano nga ulet ung servo?
May 28th, 2011 01:40 PM #14
either may problem sa bearing ng compressor and needs to be replaced or madumi tb/iacv.
- Feb 2011
- 3
May 28th, 2011 05:16 PM #15Hi po, Had the same issue. and for almost a year ko ng naeexperience ung problem. natry ko na din po palinis IACV and TB. I even Replaced IACV but still got the same issue po. Is it the compressor po ba? really need help po. TIA po
- May 2011
- 19
May 29th, 2011 01:17 PM #16nalinis ko na ung TB at IACV. ganun pa din.hindi ko pa nagagawa ung sa bearing ng compressor.
try ko.update ko kau pag umokay na.
- Jul 2009
- 31
- May 2011
- 19
- Apr 2011
- 44
May 30th, 2011 12:31 PM #19Nakita ko na ung problem kung bakit ganun problem ng oto ko... high pressure ung sa aircon ko.... the problem was in the aircon system... pero pinalinis ko narin ung servo kit ko.... ngaun nagiipon ako para sa budget sa ac ko 4k-5k ang pagawa sabi ni doc abet of sta. rosa laguna...
- Apr 2011
- 44
June 3rd, 2011 11:45 PM #20pa check mo AC mo... Saken ang problem ay Extension valve, drier at ung isa nalimutan ko na.. Bukas ko pa malalaman kung magiging OK ung oto ko pag napalitan na yang mga parts na yan...
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
