Results 11 to 20 of 22
October 5th, 2010 09:15 AM #11
- Sep 2010
- 11
October 6th, 2010 04:53 PM #12to all, thank you very much, your all a big help, i've already change my PHS (Japan) bought from FERTES for P2,250 (i dont know kung mura or mahal eto) using HONDA PSF then pnakabit so nirecommend ni DON P400.00 lng kya naka tipid ako.
to tsikot management and members thank you very much.
GOD BLESS US ALL
October 11th, 2010 04:52 PM #13
Update pala dito... I just had my power steering hose replaced.
this is for a 2001 civic ES5.
I removed the high pressure hose. this was not very hard. a 10 and 14mm wrench is all it took. And of course some muscle power mahigpit yung V-nut sa may rack and pinion end eh... Then I brought the hose to a nearby hydraulic hose shop (near floodway in pasig). The replaced the hose and recrimped the fittings using the same size hose cotton type. It was done in about 10 minutes.
Then I went to honda pasig to buy a liter of PSF.
I went home and installed the hose. Bled the PS system and checked for leaks. Everthing was in order in just half a day (most of the time spent was in traffic!)
Total Cost:
Power steering hose replacement and recrimping = 1,200
OEM Honda power steering fluid = 550
Labor = Free kasi DIY ;)
October 11th, 2010 10:41 PM #14
October 13th, 2010 10:41 AM #15
yes sir actually casa was charging me 11,900 for the hose alone they were the one who found out that my hose was leaking. wala pa ang labor diyan di ko na tinanong.
After the usual change oil service, I pulled out my car from casa and did the repair myself. I will not spend that amount for just a hose that a replacement one can do the same job.
Oh BTW ang naging CONS lang when I used the recrimped hose (pang forklift) may humming sound kapag lumiliko. The hose somewhat vibrates or resonates and it produces this humming sound when turning. But you can only hear this when the car is stopped and you open the hood. pag umaandar na hindi na rinig. Mahinang mahina lang naman yung sound and hindi rinig sa loob ng kotse.
October 16th, 2010 02:11 AM #16
mas pipiliin ko naman yung humming sounds na hindi naman naririnig sa loob ng kotse kesa magbayad ng P11,900 para lang sa hose. ano yun, ginto?! yung labor nga pala nun aabot ng 3k, yun kasi ang nabasa ko sa ibang pinost dito.
sir, kung may pics ka. kung pwede lang papost dito pag may time ka para magkaroon kami ng idea.
maraming salamat sir.
October 19th, 2010 12:53 AM #18
sir kung north or around metro manila ka Fertes mura lang yan 2,300 hose replacement lang for honda parts pero Japan made naman. tapos 400 ang labor. Eto number ni Fertes 3715443 puede icanvass mo muna . pero halos lahat ng pyesa ng honda at nissan meron sila. Or kung bandang south ka naman sa PIYEZA 8712206 meron din yan.
GOOD LUCK!!
- Sep 2010
- 11
October 19th, 2010 02:46 PM #19good day to all, ok na yong PSH ko, ang problema naman ngaun ung rack and pinion sa steering gear, may tagas na din, dnala ko sa shop dito sa 20th ave, nkita nila may leak, ung riper kit daw and need to be replace then this morning dinala ko sa honda libis, ang pnipaplitan nila is power steering hoses, steering gear box and over hauling of steering pump costing to 70K. i need your comments, suggestions, reccomendations please help. thanks
October 24th, 2010 03:05 AM #20
