Results 31 to 36 of 36
- Oct 2009
- 72
March 5th, 2010 04:23 AM #31When your power steering fluid has been top-up, your power steering hose has already a small leak, that's explain why you have a slight loss of power steering fluid. It was already due to fail, not because of the ATF that was poured into your PS, but the crack or leak in the PS hose is already there even before the guy at the shell poured ATF.
But if you look at it from the HONDA point of view, you will surely blame the ATF for it.
- Dec 2009
- 47
March 5th, 2010 07:38 PM #32Im planning to spend on replacing may car's fluids (atf, gear oil, break). I would like to take it at my trusted shell station. Any bad experiences using fluid not from honda mismo? Iwas kasi sa casa mahal di ba? Dito din ako nagpachange oil last december mukhang ok naman.
March 5th, 2010 08:09 PM #33
- Dec 2009
- 47
March 5th, 2010 08:11 PM #34Civic SiR 99 sir. Kahit ba sa older model may restriction ang atf fluid
March 5th, 2010 10:08 PM #35
March 6th, 2010 10:25 AM #36
have you read the other pages of this topic?
honda p/s fluid for p/s
honda atf z1 for a/t
use any other fluid and you will break something 99% guaranteed. hindi naman agad, baka couple months down the line habang nasa roadtrip ka.
if you have a true SiR (hindi ung SiR body lang), use 10w-30 mineral oil sa manual transmission. do not put gas station gear oils, hindi pwede yun.
what else? ah yung radiator fluid... resist the urge to put prestone. use caltex radiator fluid kung ayaw mo nung honda pre-mixed coolant (which is mahal, i myself dont use it).
