Results 1 to 8 of 8
- Jan 2009
- 163
November 2nd, 2011 10:12 AM #1Mga guru,
Need ko advise regarding may car iyong front wheel passenger side bigla po bumaba kaya po sumasayad ngayon yung gulong ko sa fender ano po kaya possible na sira? shock po ba or spring? new bhie lang po ako, honda esi po car ko 1994 model 55 series ang gulong.
Kindly need ko po advise regarding po sa budget para mapaghandaan.
Salamat mga guru in advance. God bless
November 2nd, 2011 10:17 AM #2
sumasayad na hinde mo pa pinapa check? instead na magtanong ka dito punta ka na kaagad ng talyer para makita ng actual at maayos na agad.
- Jan 2009
- 163
November 2nd, 2011 10:43 AM #3Sir,
Censya na po nagtanong lang po ako dito para may idea po ako pagpunta ko sa shop kung ano sasabihin ng mekaniko.kagabi lang po kasi nangyari pag uwi ko eh.
November 2nd, 2011 10:50 AM #4
^I'm sorry if I came on too strong but kasi it looks like grabe na eh dahil sumasayad sabi mo, so better have it check at once...it seems meron ka naman alam kahit konti sa kotse so most probably doon lang yan problema shocks, spring and other components diyan..it's not really a big problem...unless you're going to continue drive around with your car.
sa maloloko, makikita mo naman yun sinasabi kung sira na talaga eh...huwag masyadong matakot sa mga mechanic na manloloko. kung wala kang tiwala eh di huwag mo pagawa sa kanya ang move to a new mechanic. you still has the last say
BANNED BANNED BANNED
- Jul 2003
- 2,267
November 2nd, 2011 05:00 PM #5to me it looks like the spring. no matter how busted a shock absorber is, ride height wont be affected that much as long as the spring is still ok.
- 52,514
November 2nd, 2011 06:05 PM #6sounds like your ball joint finally died. the good thing is, it's probably cheaper to repair than the other suspects, because it is a wear-and-tear part.
and it should be easy to determine what the problem is. just crawl under the car (jack it up if you have to) and take a look. or you can peep over and beside the tire. compare it with the other side. and i am assuming you can't drive the car out. what you can do is to take pictures of the underside and show them to your mechanic. that way, he'll know what the problem is and will arrive at your house carrying the necessary parts..
- Jan 2009
- 163
November 3rd, 2011 10:42 AM #7
- Jan 2009
- 163
November 3rd, 2011 10:43 AM #8
Traffic!
