Results 11 to 18 of 18
June 13th, 2008 03:00 PM #11
If thermostat is stuck up engine will overheat driving or idling due to coolant are not circulating that cause boiled up. His case was happen only in a long driving not on city driving means that his radiator are partialy clogging not enough water flow to cool down when reving it up and the impeller goes faster.
- Aug 2008
- 3
August 14th, 2008 07:49 PM #12sir is it also possible din na sa aircon ang problem, lets say hindi na nag automatic yung aircon???? kaya hirap din and makina kaya nag overheat???
tenks po sa mag-rereply...
- Aug 2008
- 3
August 15th, 2008 07:51 AM #13guys help naman po i have the same problem kasi eh, mine is a 97 LXi, tenks po....
August 15th, 2008 08:10 AM #14
August 15th, 2008 08:32 AM #15
Check muna for leaks or baka kulang ang coolant, yung belt baka maluwag = apektado water pump.
Next drain mo radiator, flush and add new coolant. Kung matagal na rin ang radiator mo di na rin masama ipa overhaul.
Pag ganun pa rin, punta ka na sa thermostat pero dapat normal operating temp so need painitin ang engine, open the radiator cap (with proper caution) tingnan mo kung umiikot ang coolant – from the top engine hose going to the radiator, pag umiikot –okay ang thermostat mo – bumubukas siya or andun siya
Pag ganun pa rin, pa check mo na yung pinaka mahal - water pump
THE AUTO SPECIALIST
- Mar 2006
- 607
August 15th, 2008 11:10 AM #16
- Aug 2008
- 3
August 16th, 2008 11:05 AM #17salamat sa lahat ng nag reply mga idols.....
check ko po uli oto ko based on your advice, tenks po uli....update ko nalang uli kung may maramdaman poko......helpfull talaga thread na2 lalo na sa mga newbie na tulad ko.....
- 25
August 16th, 2008 12:14 PM #18boss same problem tayo s civic...ang problem nyan is the waterpump.. thats the reason why our car is overheating...tska pacheck m rin mga tubes na nakaconnect sa radiator to the engine baka rin may tagas na...hope it helps
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
