Results 1 to 6 of 6
January 7th, 2011 06:20 PM #1
Mga katsikoters good afternoon!, Newbie po here, Share kolang po story ko, about 2 months ago i bought a 2nd hand civic vti 96 mode M/T, and upon checking ok naman siya, no leaks or whatsoever. After a month i noticed may leak siya sa bandang transmission, i brought it sa 1st mechanic, nirepair niya and sinabi and pinakita saken na nareplace ang oil seal sa tranny and sa crankshaft, edi ok na.. a week after that may leak nanaman, dikona binalik sa una gumawa kasi ang mahal nang singil and tinry lang namen nang pinsan ko sakanya since harap lang siya nang house nila. Then sa 2nd mechanic na namen dinala which is yun talaga mechanic nang pinsan ko, ni repair nila is Power Steering leak and ball joint replacement nadin, dipadin nawala leaks, then dinala kona sa tito ko, ayun nag overhaul sila nang engine tranny and PS, ang dami nakita leaks and pinalitan na lahat mga seal, and ang timing belt, tensionair and clutch disk.. Yung leak na to is connected ba sa High Mileage nang car? Because when we got the car it's mileage is around 190k na.. After mareplace na lahat nang seals may possibility pa kaya magleak ulit? Ngayon palang kasi ako nagkaroon nang sariling car, before pahiram hiram lang sa relatives kaya la masyado idea sa mga ganyan ehe,, Thanks po in advance sa mga inputs!
January 11th, 2011 03:35 PM #2
ganun talaga pag luma, and pag may isang seal na nag leak dapat palitan na din yung iba kasi most likely pabigay na din ang mga yun.
kung orig seals binili mo (from casa) at tama ang procedure ng pag install, another 10 or more years na ulit yan bago mag leak. Pero pag replacement binili mong mga seals, gaskets expect that to leak again very soon.
January 16th, 2011 11:15 AM #3
nawala na ibang leaks sir, orig honda parts binili nang tito ko, pero meron daw isang seal sa transmission na di napalitan kaya meron pa leak sa tranny, papalitan na daw niya, kasi sinave namen iba seals na ok pa. and gumanda takbo and hatak after overhaul.. Power steering repair kits are expensive pala noh?
and one more thing sir, kasi bukas kopa babalik sakanya because i will be using it, pano ang pag add nang oil? gano kadami? my oil leve is still in middle of the 2 marks nung dip stick..
- Jan 2011
- 24
January 16th, 2011 03:25 PM #4
Ang tinatanong u b ay engine or transmission oil? kung engine pwede u dagdagan dun sa engine oil fill cap, most of honda engines ay d bumababa sa 4 1/5 litro ng langis (engine) at transmission 2litro ng gear oil, sa tranmission kailangan ng handpump oil tank kung san dun ilalagay ang gear oil at ipapump manually pra pumasok ung oil sa loob. wlang dipstick ang transmission kundi check plug lng at drain plug, ung check plug about 17mm and size at ung drain plug ay 19mm
January 16th, 2011 05:50 PM #5
January 16th, 2011 06:04 PM #6
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper grammar, sentence and paragraph construction. If your message is easier to read, more people will read it.
Read the rules.
Ignorance of the rules is NOT an excuse.
Repeat offenses will lead to banning.[/SIZE]
