Results 1 to 10 of 10
- Jul 2009
- 19
October 29th, 2010 09:14 AM #1I have a car honda city 98 which has a very noisy engine. I have already bought it to a respectable mechanic to adjust valve clearance but still no good. Last time sa cruven ko sya dinala pero hindi paren naayos. Ano na kaya problem nito?
- Jul 2010
- 165
October 29th, 2010 12:45 PM #3
all moving parts can cause unwanted noise pag sira na. have it checked by a more respectable mechanic ;)
- Jul 2009
- 19
October 29th, 2010 02:28 PM #4
- Nov 2009
- 456
October 29th, 2010 05:58 PM #5What kind of gasoline are you using? I would suggest filling up with an octane rating of 93 and above. Then observe if the noise will go away.
If your engine is long due for an oil change, I suggest to do this asap and then observe.
October 29th, 2010 06:23 PM #6
Better check the rpm or idle mo baka mataas masyado. Idle normally 700-800 rpm
- Jul 2010
- 165
October 29th, 2010 06:40 PM #7
- Jul 2009
- 19
October 30th, 2010 07:15 PM #8
October 30th, 2010 08:16 PM #9
If pagkachange oil meron pa din, try mo dagdagan STP.
pag di na makuha sa adjustment and better engine oil,palitin na mga valve lifters niya...takatakatatataakkk...
itaktak mo.... jk.
- Nov 2009
- 456
October 30th, 2010 09:21 PM #10
